Opti decisions, decisions
So put on a new Cap and rotor? or....
Just put it back on and wait for it to die dont waste the money on the cap and rotor? or....
Stop being so tight and buy a new one you idiot?
Input anyone?
Roy
Input anyone?
Roy
I am ordering parts for a ,head/cam swap, and an opti is not on my list.
Mike
Here's what I did in 2003: '93 6spd, 75000 mi, replaced opti (no crude or anything wrong with it) with a new opti, 1995 style vented, new waterpump, and GM extreme duty chain set.
Well--the brand new opti was bad from day 1 and it took 1500 mi to realize it. So I had to pay the labor for replacement anyway.
Fast forward another 13500mi from that and the waterpump also went bad--it locked up and ruined the ___itty ED gear and trashed the whole motor by flushing pieces of gear thru it.
Take my advice.
Don't mess with it.
GM is not keeping up its quality. Look at the clutch slave /master cylinder issues.
Is the time it will take me to replace it later worth $350?
My suggestion would be to save your money. I can change an optispark in about 5 hours nowadays, I've done a few. My car sits around idle most of the time so I can do the work at my liesure, and I don't mind messing around with it.
If you drive your car often, don't have garage space to leave it sit, or just don't want to have to go through the hassle again, then pay the money and do it now. If yours worked fine then that route is equivelant to buying insurance. Nobody here can tell you how long it's going to last - could be 1,000 miles or 30,000. It's just gambling.
In the immortal words of Clint Eastwood, "Do you feel lucky? Well? Do ya...punk?"
Mike
the high voltage compnents(ie cap and rotor, are the weakest link in the Optispark assembly. 70K miles is a good time to replace these 2 items, and they are not too expensive.
So ours failed only 8.5K more than you have on yours, maybe due to oil leak from intake/seals, but not sure.
Whereas I figure our Opti has a few miles/years(?) left in it before it will need replacement again (with pump this time and Dynaspark), yours might OR might NOT.
Consider not only that when it goes (not if), whereas you might have the time/energy, where might it be and the possibility of needing to tow the car, bad weather, winter weather, inconvenience, etc.
If you only drive around town to get milk and only in the summer, never in the rain and have personal free access to a flat-bed tow truck, then wait, otherwise, "don't put off till tomorrow, what you can do today"...
Hope this helps...
Admiral you are gonna love this. I live in Florida, I only drive my car when its nice out, never in the rain, and I have my own flatbed trailer.
Roy
Roy
wana adopt me? anyway, best of luck...
