Clutch master or slave, which should I replace first?
Old Oct 15, 2005 | 05:34 PM
Aaron71771's Avatar
Aaron71771
Default Clutch master or slave, which should I replace first?
Having some problems with a soft clutch pedal on my 91. About 80% of the pedal travel has very light pressure, with only the last 20% or so of travel actually allowing the clutch to release enough to shift. About 1 out of every 15 shifts the pedal goes to the floor with no release at all. Fluid seems to be holding, I havn't had to add any.
So which should I try to replace first, the slave or the master? I already have the slave off and took it partially apart, there is some rust in the bore walls...
Old Oct 15, 2005 | 06:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
Have a similar problem, doing both at the same time and eliminate any worries.
Old Oct 15, 2005 | 07:23 PM
vettenut94's Avatar
vettenut94
Old Oct 15, 2005 | 07:47 PM
froggy47's Avatar
froggy47
Do both but it's probably mostly the slave.
Old Oct 17, 2005 | 10:31 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default Master if can only afford 1, otherwise absolutely both
I presume you have tried to bleed the system.
Therefore, the Master is likely your problem, but you should replace both.
Reason? You have already confirmed the slave is not leaking past the seal (otherwise you would have mentioned the fluid in the nose rubber seal), which is the traditional failure point.
So more likely the fluid is getting around the Master's seals, reducing its output pressure.
By the way, even if you don't have the ZF transmission, ZFDOC.COM has good info on clutches which should apply, so give it a read...
Hope this helps...
Old Oct 17, 2005 | 10:48 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Definitely replace both AND the hose!
See zfdoc website for reasons, how to buy and how to replace!
To Clutch master or slave, which should I replace first?
