cracked top need help
Old Oct 13, 2005 | 04:20 PM
boxvette's Avatar
boxvette
Default cracked top need help
my acrilic top just cracked and i dont have 1100 dollars to go buy a new one so does anyone know of a filler to seal up the crack so rain and stuff doesnt get in or know of one i can buy for cheap (duck tape is what is currently holding things together but that wont last)
Old Oct 13, 2005 | 06:11 PM
FDAMFA's Avatar
FDAMFA
You can buy a refurbished one from Corvette Central for 700
Old Oct 13, 2005 | 06:16 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You can have it covered in canvis Idid that with mine about 300.00.
They always break body flex.
Old Oct 13, 2005 | 06:17 PM
Pete K's Avatar
Pete K
The crack will expand and contract as much as 1/4 inch. I tries every goop known to man. Duct tape did it for me until the new one came.
Old Oct 13, 2005 | 06:18 PM
comp's Avatar
comp
does it look like a "mock top" ???
Old Oct 13, 2005 | 06:41 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I fixed mine with a product called Weld On. I think it was #3.It is made for lexan and makes it stronger than it originally was.I had the rear corner broken off I used a long clamp and a hypo needle to apply it.Make sure it is lined up correctly before doing it cause it sets quick.Do a search online for it I got mine from a place called Sanitary.Great stuff
Old Oct 13, 2005 | 09:46 PM
Red Tornado's Avatar
Red Tornado
call your insurance agent and see if you can get the cost refunded. this assumes you have comprehensive coverage.
contact http://www.melroset-tops.com/roofs.htm
Old Oct 14, 2005 | 01:53 AM
REDC4CORVETTE
I had mine covered in black canves and you can't tell anything is wrong unless you push down on the center.
It kinda looks like a convertable half top.
On the edges they made it like the edging on a convertable top.
http://www.zip-products.com/Zip/dept...BE21C6D0EAEF2D
Old Oct 14, 2005 | 01:09 PM
viii's Avatar
viii
Mine cracked too - many years ago. You can drill out a hole where the crack appears to end. This should keep it from expanding any further. I just put clear silcone caulk in mine. I found a used painted fiberglass top and had it painted - that is my recommendation - get rid of the glass top - breaks, squeeks, etc. Astro tops also makes replacements for like $400 but I've seen some unhappy comments on the forum.
Old Oct 14, 2005 | 01:17 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Before you put in a claim consider your deductable and talk to your agent and find out exactly what will happen to your premium.
Two years ago my wife hit the side of the garage with her Lincoln LS and tore off the side mirror. The total cost to repair was $1500.00. After my $500 deductable the insurence company paid the balance. When my policy came up for renewal I was told that the premium had increased $700 per year for the next 3 years.
Maybe that's just insurence in NJ but it can't hurt to ask.
Old Oct 14, 2005 | 01:20 PM
Redeasysport
I will repeat the best way to glue it is with Weld On.Only thing better is replace it.This is assuming the crack can be pulled togther as it is not a filler.It is more like super glue.
To cracked top need help
