Ring and Pinion Specifications D44
Old Oct 13, 2005 | 04:33 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Ring and Pinion Specifications D44
Does anybody know the ring gear diameter of the D44 and how many teeth are on it? Obviously the 3.45 ratio dictates the ratio of teeth between then ring and pinion so if you know one you can figure out the other.
I've got a gear modeling program that I'm trying to mess with but without the dimensions it's kinda pointless. Information about the ring gear diameter, thickness, etc would be great. A blueprint would be fantastic.
Old Oct 13, 2005 | 04:38 PM
vader86's Avatar
vader86
8.5" ring gear
pinion shaft dia-1.375"
26 pinion splines
Old Oct 13, 2005 | 04:44 PM
Nathan Plemons
Thanks. I found a site with some ring pinion ratio info that helps as well.
http://www.precisiongear.com/dana44v.htm
To Ring and Pinion Specifications D44
