QA1 coilover setup
Old Oct 13, 2005 | 06:26 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default QA1 coilover setup
anyone have teh part numbers?
Old Oct 13, 2005 | 09:30 PM
LTxDave's Avatar
LTxDave
This is what I saved off of an old post a while back:
HAL-SS110SDM these are for the stud ends ( I have coilovers)
HAL-UPR350 these are for the t-bars which would be needed on the front bottom lower contorl arms.
I'm usinging the 4558 coilover shocks which required removing and adding the shaft for the tops on all 4 shocks.. then the two t bars on the front bottoms. The bottom rear shocks the bushings they used fit mine fine, they also had included a second set of bushing inserts. I as well used washers to align the bottoms of my shocks, but again I was dealing with coil over clearance issues.
I hope perhaps the part numbers help, I order through Summit racing...
Here is what I had to order, if you are not usnig coilovers then disregard
Qty Part number desc.
002 HAL-10-250 250# springs $36.88/each
004 HAL-SS110SDM Studs for top of all 4 shocks $32.99/each
004 HAL-DR4855P shocks $152.39/each
002 HAL-UPR350 T-Bars for front bottom shock mounts $22.99/each
002 HAL-10-350 350# springs $36.88/each
001 HAL-T114W spring adjustment tool $16.95/each
Old Oct 14, 2005 | 09:48 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
http://www.ndneyes.com/mo/coil.html
Old Oct 14, 2005 | 11:44 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I have a front set of qa1 shock, not the coil overs if anyone is interested. They are basically brand new!
Jesse
Old Oct 14, 2005 | 12:52 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Everytime this topic comes up, I always want to know, can this same setup be used on an Early C4?
To QA1 coilover setup
