85 Vette WON'T START
Old Oct 14, 2005 | 12:15 AM
Sean Dunshee's Avatar
Sean Dunshee
Default 85 Vette WON'T START
I have an 85 Vette that will not even turn over like there is NO power to the starter. My car is at my fathers house and I had a guy coming to look at it today to possibly purchase it, my dad went out to see if it was ready to be looked at (the car hasn't been driven all summer) he went out to start it and the battery was DEAD, he then jumped it with a booster charger....long story short, he bought a new battery and now there is NOTHING....it won't even crank. I had an extra ECM so I changed that thinking maybe he fried it trying to jump it...nothing different. All the other components such as the dash and the headlights etc all work fine, when you try and start it with the headlights on the headlights do NOT dim at all. Any ideas?? I really need to get this car running and SOLD. Thanks!! SEAN
Old Oct 14, 2005 | 12:27 AM
jabez's Avatar
jabez
Try a different key? VATs problem?
Old Oct 14, 2005 | 12:34 AM
Sean Dunshee
85 doesn't have VATS.....86 and newer.
Old Oct 14, 2005 | 12:49 AM
PierEagle's Avatar
PierEagle
Did you check the cable and connections at the starter to see if you are getting any power there?
Is it stick or auto? Check neutral safety switch. If stick, there should be a switch on the clutch (to make sure it is fully depressed before it will turn over). The switch could be bad.... and on and on and on.
Keep the faith.
Old Oct 14, 2005 | 10:55 AM
Sean Dunshee
I am heading over there right now to put it on my dads liuft and check the power at the starter. The car is an automatic. Are there any fuse links to the starter that anyone knows of?
Old Oct 14, 2005 | 11:26 AM
reidry's Avatar
reidry
The factory security system can act like that, interrupts the starter - is the security light on the info panel flashing like it should? Put the door key in the door lock and make sure you turn it all the way to unlock - this should have set off the horn if they are connected. Check the ignition switch down on the column too - the lock cylinder doesn't do much but drive a rod down to the actual switch lower on the column.
Ryan
Old Oct 14, 2005 | 12:34 PM
jfb's Avatar
jfb
Jump the gear selector switch. You can test the starter by jumping 12v to one of the wires on the gear selector switch which goes to the starter solenoid and this should make the starter run.
Old Oct 15, 2005 | 05:03 PM
woody1243's Avatar
woody1243
there are 2 fusable links on the starter side and there is one more on the battery possitive cable side.
good luck..
Woody
Old Oct 16, 2005 | 12:19 AM
Sean Dunshee
Thanks for all the help guys...it ended up being a dead starter. Got it changed and cleaned the car up and sold it today.
Old Oct 16, 2005 | 10:50 AM
STL84's Avatar
STL84
6th Gear
I had the samething with my '84. The previous owners disconnected the horn from the security system. So when I had the top off and / or windows down and opened the lock by reaching in and fliping the lock in the inside, the car would not start. The security totally cut of the i=gnition switch. Now eventually, the system would reset (in approx. 20 minutes) and then the car would start. Does not sound like your problem exactly, but it was driving me crazy for a while.
Old Oct 16, 2005 | 10:54 AM
jabez's Avatar
jabez
Do you miss it? Did you buy another car?
Old Oct 16, 2005 | 11:58 AM
Sean Dunshee
I have a couple other Vettes as well. I have an 87 convert, an 88 convert and a 90 convert. But I am selling and/or parting out so I can get rid of all of them. I want a 65-67 in a BAD way.
To 85 Vette WON'T START
