question about code 15 and 22 on my 1992
Old Oct 16, 2005 | 11:32 PM
Togo's Avatar
Togo
Default question about code 15 and 22 on my 1992
service manual says code 15 is coolant temp sensor - is there a way to "test for this" without a scan tool?
also, code 22 shows TPS - can i also test this without a scan tool?
i checked the FAQ for stuff - but the 1992 has a non adjustable TPS, so i'm not sure what to do.
any help would be appreciated
Old Oct 16, 2005 | 11:46 PM
bogus's Avatar
bogus
replace the temp sensor... they don't last forever.
The TPS can be tested with a volt meter. Also make sure the harness is ok.
I will have to check my helm manual for details...
Old Oct 16, 2005 | 11:52 PM
Togo's Avatar
Togo
i'm just confused - the temp sensors seem to work fine - both the analog and digital guages work - or is this sensor something different?
and where is it located? i'm so confused!?!?!?!?
Old Oct 17, 2005 | 12:51 AM
Morley's Avatar
Morley
You are thinking temp SENDERS, those feed gauges..The SENSOR feeds the ECM. As said, just replace it..they sell for around $7 at advance auto and the like.
Old Oct 17, 2005 | 10:46 AM
johnnyzvette's Avatar
johnnyzvette
I agree....change your coolant temp sensor. I also have a 92 and a while back I was having a hesitation problem under acceleration and I got the eng. temp sensor code, changed it out and the problem went away. Good Luck!
Old Oct 17, 2005 | 12:48 PM
luvmy92's Avatar
luvmy92
I was getting a code 15 and changed the sensor, and still had the problem. My problem was the piggyback harness connector in the waterpump. It needed to be replaced and that solved it.
Mike
Old Oct 17, 2005 | 01:49 PM
Togo's Avatar
Togo
Mike
so jut in case it's not the sensor - do you mean that "piggyback" connector that actually plugs into the "sensor" on the pump, or is it the sensor in the pump?
and does anyone know where this ECT sensor is? is it in the head? on the pump? the radiator?
thanks for all the input so far
Old Oct 17, 2005 | 02:51 PM
luvmy92's Avatar
luvmy92
The piggyback connector is in the waterpump.
Mike
Old Oct 18, 2005 | 05:20 PM
Togo's Avatar
Togo
ok, so i have to clarify - as i'm not the smartest!
if the sensor or the piggyback connector were bad, wouldn't the DIGITAL temp guage not work?
i remember when i had some work done a while back, he forgot to plug the connector back on the pump, and my temp registered 130 and never changed.
wouldn't this do the same thing of the ECT was bac?
just curious?
Old Oct 18, 2005 | 05:33 PM
luvmy92's Avatar
luvmy92
just curious?
My digital temp guage went all over the place and would finally settle at 142. BTW, you go into limp home mode when this code is set. Not conducive to road racing let me tell ya.
Mike
Old Oct 18, 2005 | 06:11 PM
Togo's Avatar
Togo
a'ight, that settles it, i'll get a new sensor today and try and get it changed tonight, then reset the codes and see if it goes away.
i heard removing the positive battery terminal would reset codes - and it only must be left off for 30 seconds - is this true?
Old Oct 18, 2005 | 08:05 PM
dlmeyers's Avatar
dlmeyers
The Coolant Temp Sensor is very inexpensive and no problem changing it out. They may loose some degree of sensitivity over the years and I replaced mine just 'cause it was there when doing some other work.
I recommend checking a wire diagram for your model year. Just looked at the schematic for my 90(Page 8A-20-1 Electrical Supplement) and the Coolant Temp Sensor and Throttle Position Sensor come together at Splice120, form a single wire, then goes to a ground in the ECM (Electronic Control Module), pin G10. Your wiring and splice numbers are likely different but with two problems at once, I'd check to see if the circuits share connections.
The codes listed should disappear as noted. Some other codes, say ABS, will not.
Good luck with this repair and let us know.
dlmeyers 90 coupe zf6 3 speed shocks
Old Oct 19, 2005 | 01:37 PM
Togo's Avatar
Togo
this concerns me a LOT - while the temp sensor change sounds easy enough, and i know how easy it is to replace the TPS on this car,(it's been off half a dozen times) i'm guessing for a measely $28 i should just replace the TPS as well!
anybody think that's a bad idea?
now - what concerns me is the wiring - good grief, i'm a certified 'parts changer' not a mechanic!
anyone know where i should be looking for a possible wire issue on this thing?
Old Oct 19, 2005 | 07:29 PM
CFI-EFI's Avatar
CFI-EFI
Not if you have money to burn. If you throw enough cash at a problem, you CAN make it go away. Certainly, your Helms tells you how to check the operation of both the temp sensor and the TPS. Don't shoot the messenger. If the components check out, the manual has trouble shooting charts to help avoid wasting time and money.
RACE ON!!!
Old Oct 21, 2005 | 04:24 PM
Togo's Avatar
Togo
well i threw $9 at it for the ECT and it took all of 10 minutes to replace - and 20 minutes to burp the system - and i think it can still be done some more!
i think i'm gonna throw another $28 at it for the TPS sensor and call it a day - if that doesn't fix it, then i'll be tracking wiring - it looks like both those sensors meet up along with the IAT or whatever it's called as far as wiring goes, so that'll be my next task if this doesn't work.
Old Nov 21, 2005 | 02:10 PM
Togo's Avatar
Togo
thought i'd throw in an update - after i replace the ECT nothing changed -
well i finally put a new TPS on the car - and all my codes went away - INCLUDING the service ASR code i had!!!!
Old Nov 21, 2005 | 02:39 PM
CFI-EFI's Avatar
CFI-EFI
Atta way to trouble shoot!
RACE ON!!!
To question about code 15 and 22 on my 1992
Old Nov 21, 2005 | 03:11 PM
SunCr's Avatar
SunCr
Both share the same ground - so usually if it opens, you get the multiple codes. Sounds like you had a loose connection.
Old Nov 21, 2005 | 04:13 PM
ittlfly's Avatar
ittlfly
RACE ON!!!
Seriously Togo....you should invest in a set of Helm manuals for your car. I think that's what CFI-EFI is tactfully eluding to. There was a set for sale for a 92 over in "parts" awhile back. You might check.
Old Nov 21, 2005 | 04:22 PM
Togo's Avatar
Togo
i have a set already - but man are they cryptic - there is almost TOO MUCH detail in them - if that's even possible.
besides the fact that i don't have a scanner or laptop application that works with my '92 - it makes things that much harder - and yeah, i'm a bit lazy too!!!!
