rear end ratios
Does anybody have any suggestion on ratios? i would think that a 3.54 would be as high as i wanted to go, and that might be to high?
In looking over the repair manual it is calling for a carrier spreader, and several other special tools, is this really required?
i do have the tools to set the depth and backlash and have done a few rear ends before, just never have done a Danna 36 before.
How bad a hit am i going to take on mileage if i do go to a 3.54? it has a 2.59 in it now.
a 3.07 is a nice jump. probobly your best bet with a supercharged car if its very mild i.e:stock cam/heads/intake.
2.59's are for people who like topspeed and do interstate traveling and need decent mileage.
3.31's are probobly not gonna come around since in 84 there where only 410 cars ever made with that special ratio.
3.54's will be probobly too much. probobly won't have traction whatsoever and for a very narrow powerband they just won't cut it very well. 1/8th mile ET times would get better but after that it probobly won't do the car any justice.
3.07s and 3.31s from other automatics are for the 3-series carrier, you have a 2-series carrier.
Nearly all aftermarket manufacturers who make 3.54s/3.73s for the D36 are making them for the 2-series. It would probably be too much for an L98 with SC on top, you'd have no traction.
The reason iam saying i was thinking my 85 auto vette has a 2.73 ratio but it end up being a 3.07 and i changed to 3.54 dana 36, dman i would have gone to 3.73 i did not see much diff going from 3.07 to 3.54.
If its ur's a 3.07 (which i believe i might be wrong but u have to make sure) i would suggest going to dana 36 3.73.
Tpis sells them in 3.73 ring and pinion and let it installed by lamar walden in doraville, buford hwy 770-449-0315 atlanta.
Tpis also sells drive and driven gears for ur speedo correction or ask CFI-EFI for speedo related issue.
Dana 44 cost money more than 1200 bucks easily.
RACE ON!!!
How much trouble is it to change to the 44? i am considering this, not real sure how the 36 will hold up when i go for more power, so that might be prudent to go ahead and change it over to a 44.
Vader86, i thank you for the effort you put into you home page, LOTS of good info there.
I need to do the work myself, i own a shop that does mostly European cars. i would have a hard time if i paid some one else to do the ring and pinion for me, plus i still enjoy doing the work myself. (if anyone needs any help with there cars that are made in Europe, i will try to help)
in writting this response, i guess i have decided to go ahead, save my change and spring for a danna 44, i do plan on building at least a 383 when this motor goes bad (not long i fear) with a 3.07
I pulled 2-36's and swapped them back in the 2 cars, the total job was right around 4 hours. It really isn't that hard to pull these rearends out.
What all do i need, the housing, batwings, beam? does this require a drive shaft swap?
It's no biggie without a lift either.
I had the same motor/car you run in another one of my cars but a convertible, so it had 2.73s. Coupes came with 2.59s with the auto or an optional 3.07. Manual cars came with the 3.08 gears. All auto cars were D36, while manual cars were D44.
That same combo: S/C 350 ci auto, basically stock, works well with either a 3.08D44 or a 3.33D44. I would not suggest any taller, as you should have the grunt to easily pull these gears.
For a blown manual car (4+3), I would recommend the 3.54s, while a ZF works well with 3.45s or 3.73s.
The swap to the D44 is very straightforward (batwing, chunk, driveshaft, and ladder). I have the complete D44, if and when you are ready).
Aaron
