Speedometer calibration....
Old Oct 20, 2005 | 11:53 PM
65coop's Avatar
65coop
St. Jude Donor '05
Default Speedometer calibration....
The car is a '90 L98 w/ 700R4 - I recently installed a D44 w/ 3:91 gears from a D36 w/ 2:73 gears -- The car has an automatic now and will be swapped out for a ZF 6 speed in a few weeks..
I was wondering, what do I need to change - to correct the speedometer for the Auto vs. the ZF? is it the same part for both?
Or....should I just leave it alone until I do the swap?
Old Oct 21, 2005 | 12:25 AM
sami85L98's Avatar
sami85L98
Let the cFI-EFI chime in but assuming u have 275/40/17 wheel tire combo with 3.91 gears according to bowtieoverdrives.com
15tooth -drive gear grey
45tooth- driven gear.
but as i said let the CFI-EFI chime in and correct it.
Old Oct 21, 2005 | 12:32 AM
65coop's Avatar
65coop
St. Jude Donor '05
Nope.. They are 315/35/17
Where are you CFI-EFI??
Old Oct 21, 2005 | 12:37 AM
65coop's Avatar
65coop
St. Jude Donor '05
After reading your post again... I think your telling me that I have to remove the tail shaft housing to do this?
I hope not... If so, the speedo will be off till the ZF goes in.
Old Oct 21, 2005 | 01:15 AM
WVZR-1's Avatar
WVZR-1
Default Speedo
Sam,
I'll check that for you in the AM 1st thing
Old Oct 21, 2005 | 03:43 AM
sami85L98's Avatar
sami85L98
Yes u have to take out tail housing but thats not a pain, the pain job is to remove drive shaft to get acces to tail housing to replace this but considering installing blk box (abott or dakota) more expensive and involved wiring and drilling too.
Mine is a 85 vette i installed blk box but at that time i dont have info to replace just drive and driven gears, this will be preferable than installing blk box in my view and others too.
But be careful replacing those drive and driven gears, installing wrong kind again u have to do all over again replacing exhaust (partial) and drive shaft to get access to tail housing.
I used this link to calculate speedo gears and even with 315/40/17 iam getting same 15 tooth and 45 tooth.
http://www.700r4.com/speedoCalc/speedocalc.shtml
Old Oct 21, 2005 | 07:30 PM
CFI-EFI's Avatar
CFI-EFI
Interestingly, when *I* used that link, it read to use a 15/43 tooth combination with those tires and 3.91 gears. Those are the same speedo gears Chevy uses with 3.54 gears with 315/35/17 tires. With these larger tires I think I'd go with the dark grey 44 tooth driven gear, part number 25513051, along with the grey 15 tooth drive gear. The part number of the drive gear will depend in what year transmission you use. For 1990 and earlier, it's a 8642620; 1991 and later, 1250670. The problem will be getting a hold of the 1990 and earlier, 40 tooth + VSS, part number 25007308.
RACE ON!!!
To Speedometer calibration....
