Installing Poly Bushings
Old Oct 22, 2005 | 09:18 PM
klita's Avatar
klita
Cruising
Default Installing Poly Bushings
I've bought new poly bushings for my 85 rear sway bar. Removed old rubber ones but when forcing new poly bushings into sleave using a vice they are about 1/4 inch longer than the old ones. Has anyone else had the same problem. Any advice would be appreciated.
Andy
Old Oct 22, 2005 | 09:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I did that job earlier this year and had no such problem using the black ES bushings.
Will the links still bolt up the the chassis and to the sway bar??
Old Oct 23, 2005 | 02:00 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
I had the same proble with my 86 when I used new GM parts. I used a C-clamp and socket to press the new bushings in the sway bar while on car. Also used a lot of silicon spray.
Cheers,
Frank
To Installing Poly Bushings
