Spark Plug & Ignition Opinions Needed
Old Oct 23, 2005 | 11:51 AM
williammackean's Avatar
williammackean
St. Jude Donor '07
Default Spark Plug & Ignition Opinions Needed
I thought I'd have a look-see at a plug in my '85. Wow. They look like original ACDelcos! Badly worn.
So, I was thinking of replacing these plugs with Bosch Platinum +4's and replacing the wires and HEI with Accel products.
Has anyone had any good or bad experiences with these? Any suggstions?
-Kyle
Old Oct 23, 2005 | 12:12 PM
tjwong's Avatar
tjwong
-Kyle
For a little more cash outlay you can get the Denso Iridium plugs which work better than the Bosch plugs. The Densos actually work as advertised and there is actual documented gains with these plugs. Not like the marketed hyped up BS like the Split fires and other fancy plugs. As for Accel products they are fine, no sense going to these ultra large wires such as the 8.5mm or even 10mm wires 7mm or even the new Accel 5mm wires will also work fine. Personally I prefer the Taylor wires in their Spiro Pro product line.
Old Oct 23, 2005 | 04:12 PM
sami85L98's Avatar
sami85L98
Bosch platinums are good for LS1 motors thats what i heard, not many TPI guys are not happy with platinums but i had a bosch 4+ for aluminium heads(mine is dart pro Al angle heads) for a while it worked pretty good.
check 65z01's website for info on this:
http://www.geocities.com/jgkov/TPSService.html
Old Oct 24, 2005 | 12:15 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
My '85 didn't like the Bosch Platinums at all (the regular ones, not the +4's). Switched back to the regular AC Delco plugs and the car started quicker and runs fine.
To Spark Plug & Ignition Opinions Needed
