4+3 Question.....
Old Oct 23, 2005 | 12:39 PM
88BlackZ-51's Avatar
88BlackZ-51
Default 4+3 Question.....
I am in the works of building a motor, It should have 400RWTQ at the low end. Question is, If and when the 4+3 goes, Can it be rebuilt alot stronger then the stock unit?
I think eventually the tranny will spit out, I think this might be the weak link. BTW, No major problems yet, I usually depress the clutch when I engage the OD.
Thanks.
Are there any guys with some good power behind there 4+3? and if so how are they holding?
Old Oct 23, 2005 | 01:11 PM
easycreeper's Avatar
easycreeper
The four speed portion of the transmission is apparently very stout. I have an 88 Callaway pushing 420rwhp and 586rwtq through it. Unfortunately, the overdrive unit has not fared so well though and ceases to function any more. Good luck with your buildup. Keep us posted with your numbers when you complete.
Justin
Old Oct 23, 2005 | 01:27 PM
88BlackZ-51
Justin
That is good to hear Justin that the 4 speed is handling that stout motor you have........586rwtq, geez.
So what happened to your OD unit? You driving the car with just the 4 speed?
Old Oct 23, 2005 | 01:36 PM
easycreeper
Yup, just the four speed. I think the OD unit might have seen one too many top speed runs... Still getting 20+MPG at a 65MPH cruising speed.
There's quite a bit more power to be had from the engine with an advance in timing and a little more octane and boost, but race fuel is hard to come by and is ridiculously expensive, so...
What kind of internals are you using? Displacement?
Justin
Old Oct 23, 2005 | 07:43 PM
Dominic Sorresso's Avatar
Dominic Sorresso
GM is offering some good deals on ZF-6s. I did that on my Xfire. Best mod I ever did along with upgrading to C5 brakes.
Old Oct 24, 2005 | 01:58 AM
88BlackZ-51
the 4+3 keeps my car unique man, its a conversation piece.
Old Oct 24, 2005 | 03:46 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The 4 speed ST10 unit is strong.
When you're not in od, the entire assembly rotates as one piece.
So... basically, don't dump 400 ft lbs when in overdrive and you'll be fine.
Old Oct 24, 2005 | 05:37 AM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
exactly.
my buddy wants me to do an upgrade to a 6 speed, but i keep tellin him "hey, my OD unit works, more than most can say"
Old Oct 24, 2005 | 10:42 AM
88BlackZ-51
Originally Posted by flaagan
exactly.
if your buddy is going to give you $2000-$3000 to do it, then maybe do it.
Old Oct 24, 2005 | 10:45 AM
Dominic Sorresso
I don't mind talking about the 4+3. But I much enjoy driving the ZF. That and the C5 brakes make my Xfire very unique.
Old Oct 24, 2005 | 11:04 AM
88BlackZ-51
i get your point, but my car is very clean, and i want to keep the tranny stock.
Old Oct 24, 2005 | 11:20 AM
Dominic Sorresso
There's no question that the decision to swap in a ZF trans makes it extremely difficult to take car back to stock 4+3. I looked at that trans tunnel for a long time before cutting it to allow the ZF to fit.
Old Oct 24, 2005 | 11:34 AM
CentralCoaster
fwiw, I broke the 4speed part of mine. The 85 overdrive works like a charm, and I use it too. I'd use it to force downshifts coming out of tight turns.
Old Oct 24, 2005 | 06:15 PM
flaagan's Avatar
flaagan
St. Jude Donor '12
actually, he has a low mile 89 'vette engine and 6 speed setup he wants me to use, currently in his camaro.
Old Oct 24, 2005 | 10:23 PM
black88z51's Avatar
black88z51
first gears blows alot. No, there is nothing you can do to beef it up. I asked the shop before, all they did was upgrade the bearings to brass.
To 4+3 Question.....
