Door panel install??
Old Oct 24, 2005 | 01:27 PM
Strike3's Avatar
Strike3
Default Door panel install??
I've done this before on the passenger's side of my 1987 coupe. But now I'm replacing the driver side door trim panel and I can't get the manual door lock installed in the accessory panel and get the metal rod into the back of it.
Anyone had this problem?? I worked on this to the point of frustation. I've even undone the door lock from the back of the door to try to make the rod more manuverable.
Any sequence information or trick will be appreciated.
Old Oct 24, 2005 | 01:51 PM
Bob CTS's Avatar
Bob CTS
On my 86 (if same) I left off the door handle bezel intalled the door panel, locked the rod (pushed to latch side on door, locked position) then pushed the rod through the hole on bezel while holding dorr handle in open position, installed bezel, then installed plactic piece onto the lock rod.
Bob
Old Oct 24, 2005 | 02:52 PM
kehler's Avatar
kehler
Don't know if this will help as I have an 84, but if you look on the handle insert there is a cutout on the top. It can't be seen looking staight on. Your put your panel on and move it into position but higher, then you move it down into position and the metal locking bar will slip through the upper cutout. I did have to use a screw driver to add alittle prying action.
Old Oct 24, 2005 | 09:22 PM
Strike3's Avatar
Strike3
Thanks guys! I'll ry your methods. I was about to loose it after several hours of wresteling with it
Old Oct 24, 2005 | 09:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The panel will slide forward just enough to allow you to reach in with a piece of metal (bent coat hanger works) and hook the lock rod.
Then you can pull the rod outward as you slide the panel back.
To Door panel install??
