ECU flag/item questions
I'm attempting to learn how to tune my own calibrations, in part by comparing a stock BIN with some modified ones I have. I've got an 86 4+3, which I'm told uses the $32 ECU. I've got a couple questions about labels and such I'm seeing using TunerPro. Most of them are pretty self-explanatory, but some aren't.
1. Why do I see a lot of "Item Not Defined" entries when I do a diff between two BINs? Is it just that many addresses are not used for anything in this ECU?
2. Under flags, what does AF Opt Wd 1- bit 0 - ManT mean? There's a setting for manual transmission in some of the other ECUs I was looking at (like $6E), but no obvious one in this ECU. Is it this flag? If yes, that'd mean one of my custom chips was burned for an automatic. That'd confuse the overdrive a bit...
3. Also under flags, what does AF Opt Wd 3 - Bit 5 IntR mean?
4. Still under flags, what does AF Opt Wd 4 - Bit 3 CCPi mean?
5. To turn off something (like the EGR), would that use a value of 0 or 255 ($FF)?
Is there a good reference for these flags? The two Chevy tuning books I have don't go into much detail about the ECU.
Thanks much.
[RICHR]
Thanks much.
[RICHR]
Thanks much.
Thanks much.
