Need A Pcm!!
Old Oct 25, 2005 | 04:05 PM
Z282C4's Avatar
Z282C4
Default Need A Pcm!!
Where can i get another 94 6 speed stock computer? a local speed shop said that they can't read it with LT1 edit, but it works fine in my car. Do i need a new pcm?
Old Oct 25, 2005 | 06:16 PM
VenkmanP's Avatar
VenkmanP
Search is your friend, and ours.
http://forums.corvetteforum.com/show...86&forum_id=55
Old Oct 26, 2005 | 01:20 AM
tjwong's Avatar
tjwong
If it runs fine in your car I doubt you need a new PCM. It could be the shops cable or software that is having issues reading your PCM. What do you need done? If its not working I can fix it by replacing it with new flash memory chips and sockets and reflashing it with a fresh GM Cal.
Old Oct 26, 2005 | 01:25 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Old Oct 26, 2005 | 07:30 PM
Z282C4's Avatar
Z282C4
the shop was reading the computer so that they can put a program so that i can start my car and have a base tune before it is dyno tuned. since the computer operates my car, i can't imagine i need a new computer????
Old Oct 27, 2005 | 12:31 AM
tjwong's Avatar
tjwong
I agree, I am not sure what your shop is using to read your PCM. I use a GM Dealer tool, namely a TECH2 which can reflash any current GM PCM, VCM or body module not to mention a myriad of other tests and operations.
Old Oct 27, 2005 | 02:54 PM
Z282C4's Avatar
Z282C4
is this something you are willing to take a look at for a fee?
To Need A Pcm!!
