'89 Groaning during turns??
Old Oct 26, 2005 | 08:16 AM
1stC3Vette's Avatar
1stC3Vette
Default '89 Groaning during turns??
Every so often, I hear a groan when I take a right or left turn at mild speeds. Not going too fast, but enough to enjoy the turning control of the vette.
The problem was there before I replaced the serpentine belt. I will be changing the shocks in the next two weeks, is there anything in the wheel hub area that I need to check or has anyone had a problem with the steering pump?
Thanks,
Dino
Old Oct 26, 2005 | 08:31 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Just Monday night I removed the return hose on my power steering fluid resevoir and drained all the old 'ATF' out of the system and refilled it with a quart of the Valvoline synthetic power steering fluid (about $4.00 at AutoZone). No groaning and smoother steering. Give it a try!
Old Oct 26, 2005 | 07:54 PM
Slalom4me's Avatar
Slalom4me
Dealers and independents will be able to offer a P/S flush, too,
if you prefer to let others get dirty. Shouldn't be costly.
The BG Products equipment is popular
Only stipulations I can think to suggest is to be sure they
don't use any snake-oil cleansers, that they refill with a
quality Dexron III (or better) and that they cycle the steering
lock-to-lock with the fr wheels elevated.
If the problem persists, then perhaps the seals in the rack
are aging. I have NO EXPERIENCE with it, but I have seen
others post that they have had results with Lucas P/S
conditioner. Do a search to review.
Old Oct 27, 2005 | 08:16 AM
1stC3Vette's Avatar
1stC3Vette
Thanks for the suggestions. I will completely drain the system and refill with the synthetic power steering fluid.
Hopefully, this will take care of it.
Thanks,
Dino
Old Oct 27, 2005 | 10:22 AM
Slalom4me's Avatar
Slalom4me
Well, I'll be interested to hear how using a synthetic in a system
with symptoms of failing seals works out for you.
To '89 Groaning during turns??
