New Lifter problem
Old Oct 26, 2005 | 09:34 AM
87 covertible's Avatar
87 covertible
Default New Lifter problem
Just got the motor in , all new . After getting the heads and intake on , started installing pushrods and rockers . When adjusting , I noticed one doesn't push down like the rest . Any ideas ? Tap on it , see if it frees , pull manifold back off and remove the lifter . It's acting "solid" . Got me worried . Was going to start up this weekend , but this maybe another in long line of setbacks. Could this one be pumped up from the preoilling ?
Old Oct 26, 2005 | 09:43 AM
Pete K's Avatar
Pete K
I thought the same thing when it happened to me this summer. Turns out the lifters were bottomed out and were missing the spring that held up the plunger. I ripped down the motor and Crower sent a new set. They seemed fine and I ran the motor. At 4k on the dyno, all the lifters fell apart. It cost me a motor. If they are Crower lifters, get your money back and buy something else.
Old Oct 26, 2005 | 09:49 AM
87 covertible
Mine are Comp Cams . This one that's in question , the plunger isn't bottomed . It doesn't compress at all when I push on the plunger . The other 15 do .
Old Oct 26, 2005 | 10:49 AM
Pete K's Avatar
Pete K
Look closely at the snap rings. If I remember corectly, comp uses 1 style snap ring for solids and another different type for hydraulics.
Old Oct 26, 2005 | 12:08 PM
Red Tornado's Avatar
Red Tornado
Old Oct 26, 2005 | 06:02 PM
87 covertible
Any other ideas ? Guess I'll call their tech line . Will post the answer FYI .
Old Oct 26, 2005 | 07:19 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
See if this thread helps.
http://web.camaross.com/forums/showthread.php?t=394574
Old Oct 27, 2005 | 11:41 AM
rick lambert's Avatar
rick lambert
Good luck. On the safe side I'd probably pull the damn thing-better than a flat lobe on the cam.
Old Oct 27, 2005 | 12:00 PM
Qiken's Avatar
Qiken
Old Oct 27, 2005 | 04:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Call CC; if they can't come with a way to free up the lifter, pull em and see what's up.
BTW, it is a roller cam in your '87?
Old Oct 27, 2005 | 07:20 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
If they are the 858's your in trouble!
Comp Cams just replaced all mine.
F-body guys are real upset with comp cam,rollers.
I just got all of mine replaced.
Old Oct 27, 2005 | 08:32 PM
89corvetteken's Avatar
89corvetteken
Default Lifters
I just ran into the same problem installing CC RR's on my new motor.
When I went to adjust the lash half of the push rods would not budge
the plunger in the lifter.I ended up pulling them out and taking them apart.It turns out that from soaking them in oil some had the oil traped inside and were acting like a solid.I drained them out,made sure the plunger was working freeley and put them back together.They work fine now but it was a PIA especially when your talking new parts,new motor.Part number was 850-16.
Old Oct 28, 2005 | 09:43 AM
87 covertible
Same thing here . Last night , turned the motor over a coulpe times , and it returned to normal . Thanks for all the responses !
To New Lifter problem
