""which Spark Plug Wire Where??""
Old Oct 27, 2005 | 06:13 PM
chillcat's Avatar
chillcat
Default ""which Spark Plug Wire Where??""
After fixing one problem I've created another...I took off 2 wires off the dist. to make more hand room for a sensor under the plenum. I removed a 3rd wire and now I'm screwed...I forgot which wire go's where on the dist. How in the world do I hook this back up right.
Old Oct 27, 2005 | 06:19 PM
zoro's Avatar
zoro
I think nearly all chevy small blocks are 18436572 firing order
Old Oct 27, 2005 | 06:27 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
front of car
1 2
3 4
5 6
7 8
distributor
..1.8..
2....4
7....3
..5.6..
Old Oct 27, 2005 | 06:33 PM
zoro's Avatar
zoro
that's a good diagram!
Old Oct 27, 2005 | 06:54 PM
chillcat's Avatar
chillcat
Hey thanks---thats pretty nifty, I'll be sure to write that down for future use also--Thanks a Bunch!!!
Old Oct 27, 2005 | 07:02 PM
CFI-EFI's Avatar
CFI-EFI
Besides being in the factory manual you asked about, it is also cast into the intake manifold.
RACE ON!!!
Old Oct 27, 2005 | 07:06 PM
CentralCoaster
And for fun...
Ford SBF:
distributor (counterclockwise)
..1.8..
5....7
4....3
..2.6..
front of car
5 1
6 2
7 3
8 4
International Harvester, just one of many V8s:
..1.8..
2....6
7....5
..3.4..
front of car
2 1
4 3
6 5
8 7
If you look closely, you'll see that all these firing orders are exactly the same, just the cylinders are numbered differently (and the distributor spins backwards from chevy)
To ""which Spark Plug Wire Where??""
