Steering column drawings....
Old Oct 28, 2005 | 05:14 PM
dchildress's Avatar
dchildress
Default Steering column drawings....
I have a 94 6 speed LT1. On my trip to Gatlinburg last week I noticed my hi-beam switch quit working (would not even click). Then the cover for the turn signal switch popped off. Then when we got home and I flipped the tilt up to get out, a hinge pin (I am assuming)popped out onto the floor and the steering wheel felt like it was unbolted. I got the pin back in, and the plastic piece over it and the cover, but cannot figure out the top end of the hi-beam rod to the TS switch connection.
Is there anybody out there who knows where I can get some good drawings or tell me how things go together? I went to the dealer and got a print out of the parts detail but it does not show how things fit together. My Haynes manual SUCKS.
Live happily and breathe tire smoke for good health.
Old Oct 31, 2005 | 09:01 AM
dchildress's Avatar
dchildress
Bumpin' myself.
Old Nov 1, 2005 | 11:03 AM
dchildress's Avatar
dchildress
Originally Posted by dchildress
Bumpin' myself.
One more time.
Old Nov 1, 2005 | 02:31 PM
TA's Avatar
TA
Not sure if this photo will help you, but if it does I have a bunch of others in various states of disassembly.
Old Nov 1, 2005 | 05:06 PM
dchildress's Avatar
dchildress
Man, I am getting close. I actually needs pics of the left side of the column - mainly how the high beam rod is located. Thanks.
Old Nov 1, 2005 | 05:13 PM
TA's Avatar
TA
Sorry, I don't have any pics of the left side. I can tell you that in my picture the two silver headed screws on the left are the ones that hold the turn signal stalk to the interior mechanism. I didn't think you remove the stalk without removing them.
Old Nov 2, 2005 | 04:45 AM
DieL's Avatar
DieL
Ta if you dont midn me asking why you had yours apart? Ive had that wiggle problem with mine im trying to get rid of.. im going to assume you have it apart to tighten the bolts. i have a post i just put up today but do you know of any fixes for that problem.. or if it can be rebuilt etc ?
tia
Old Nov 2, 2005 | 06:36 PM
TA's Avatar
TA
I took mine apart to replace the ignition cylinder. There are three (or possibly four) large torx head bolts pretty deep into the ignition that I tightened up while I was in there. I had heard that this could help the "wiggle" problem (my columns got it also). It helped a bit but didn't cure it completely. I think there is a bolt hole somewhere in there that gets elongated and causes the problem. Someone who's successfully repaired one could probably give you more details.
To Steering column drawings....
