Computer Controls-Simplified?
Old Oct 28, 2005 | 08:54 PM
bigjack's Avatar
bigjack
Default Computer Controls-Simplified?
Can anyone help me to improve performace by giving me the skinny on the computer in my '85? I've got an '85, 406 c.i. S"Ram, 219 cam,AFR heads,headers, 4+3 trans., chip by Ski. What can I do (computerwise) to improve or tune for better 1/4 mile trips? I'm ignorant of the scanners,tuning devices, etc. that everyone talks about. Simply need to know if anything should be done "from where I'm currently at". Thanks in advance, Jack
Old Dec 6, 2005 | 08:54 AM
q2blaster@work's Avatar
q2blaster@work
Default datalog
Do some datalogging, put it on the dyno, send all info to Ski he will get you dialed in. He did a great job on mine, car has never been so responsive, and he did a great job configuring my 4+3 to work the way I wanted.
Old Dec 6, 2005 | 10:20 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
This is a good primer on "How to do it and why":
http://www.thirdgen.org/newdesign/tech/promintro.shtml
Old Dec 6, 2005 | 11:21 AM
tjwong's Avatar
tjwong
The problem with dataloging that old 870 ECM is that the ECM has a very slow datastream which means that by the time he gets down the quartermile he is still receiving the data from the 60 ft mark. I know I am exaggerating a little here but it is very slow. In my opinion he would do better by tuning the car on a chassis dyno under controlled conditions with some good external instrumentation connected to the car. A good tuner with a emulator on a chassis dyno can easily dial that car in. In case you don't know what a emulator is, it is a device that plugs into the ECM where the prom resides. It takes the place of the prom and holds the prom image. When connect to the ECM the operator can make live changes during a tuning session. Once he beleives that he has a good image (tune), the file is saved and a prom is programmed, which is then installed back into the ECM.
To Computer Controls-Simplified?
