Super Ram install
Old Oct 29, 2005 | 04:28 PM
87 covertible's Avatar
87 covertible
Default Super Ram install
How on earth do you get the runner to plenum bolts in ? I can barely get 1 finger to a couple of the holes . How am I supposed to get the bolts there and started . I'm very close to pulling it back off and getting SLP runners and ported plenum . This is rediculous !! Any help would be appreciated !!! Anybody in the SF bay area want to come help ?
Old Oct 29, 2005 | 05:32 PM
Slalom4me's Avatar
Slalom4me
These threads might be helpful.
07-16-2005, Question on superram install...
09-09-2005, Avoid problems installing Superram
Install questions for the SR come up often, a lot of knowledge lies
in the archives.
Old Oct 29, 2005 | 05:42 PM
LD85's Avatar
LD85
I drilled clearance holes in the plenum and tapped the runner holes, I put button head bolts long enough for them to stick out the bottom of the plenum,
I drilled a hole through the diameter of the bolt and put a cotter pin in the hole so the bolt could never get free and get into the engine.
Old Oct 29, 2005 | 06:12 PM
87 covertible
Cool idea , Thanks ! Think I'm going to drill & tap for at least the 2 center inside on both sides .
Old Oct 29, 2005 | 07:03 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I used a very small scredriver ratchet with a hex bit.
Worked every well. I took they whole thinking apart because I forgot to run the transmission cable under it.
Old Oct 29, 2005 | 07:23 PM
87 covertible
You wouldn't happen to have an extra set of runner to plenum gaskets would you ? Guess I'll end up ordering from Summit , and try again next weekend to get her running !
Old Oct 29, 2005 | 07:34 PM
Coupe89's Avatar
Coupe89
Old Oct 29, 2005 | 08:57 PM
USAsOnlyWay's Avatar
USAsOnlyWay
I used a ratchet style box end 1/4 wrench for them and then a ratchet wrench 1/4" drive with a 1/4" u joint to get the rest, Took a while, but didn't seem too bad. Valve covers had to be off though.
A tip from Corvette96, slot the runner-plenum bolts so that way you can thread them in at first with the screwdriver through the plenum.
Old Oct 29, 2005 | 09:04 PM
Hole-Shot's Avatar
Hole-Shot
It's not that bad. Just be patient.
Slotting the runner to plenum bolts as mentioned is a good idear.
Old Oct 30, 2005 | 03:49 AM
86PACER's Avatar
86PACER
If I ever install one of these I'm putting the runner bolts in from the top.
Old Nov 12, 2005 | 12:12 PM
Eike's Avatar
Eike
I slotted all the bolts at the end. Then you can hold them with one finger against the hole, and use a srewdriver from the top to get them in (ccw). Just for gettig in, not for the final tq.
Old Nov 12, 2005 | 01:41 PM
scorp508's Avatar
scorp508
You have an '87 I guess by the name? You will not be able to re-use the hardened metal lines that ran under the normal runners. They won't fit under superram runners. You will have to order the '88+ versions of these lines.
Old Nov 12, 2005 | 09:45 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you talking about the pcv and canister vacuum line ?
I have a super ram on the way so i'm keeping my alert
Old Nov 12, 2005 | 09:51 PM
scorp508's Avatar
scorp508
Yup. There is a line on the passenger side too for the breather valve that goes to the throttlebody. Those have to be replaced with the 88 and up versions. Cheap parts.
Old Nov 12, 2005 | 10:12 PM
AGENT 86's Avatar
AGENT 86
Thanks, should i be looking to GM or is there a sane priced part somewhere else.
Old Nov 12, 2005 | 10:23 PM
USAsOnlyWay
I just replaced mine using vacuum tubing and some 90* bend parts.
Just an option if the GM route is too pricey.
I didn't even hear about that till after I had figured out my own way.
Also, I wouldn't install them from the plenum. I am sure they wouldn't work themselves out. But as I see it, I would rather spend hours upon hours (it actually was't that bad for me though...) installing the plenum than have an entire cylinder head/motor wiped out by a run-away bolt.
Just something to think on...
Old Nov 12, 2005 | 10:38 PM
scorp508's Avatar
scorp508
A valid concern. Red Loctite and lock washers have kept mine in place inside the plenum for 22k miles and have been on and off more times than I want to count. Safety wire could also be used if you wanted to drill a hole in the bolt and clean the threads up.
To Super Ram install
Old Nov 13, 2005 | 12:04 AM
comp's Avatar
comp
in the archives.
link
Old Nov 30, 2005 | 05:56 PM
csheerin's Avatar
csheerin
Is it really worth it? I have installed the new intake (almost a year ago) and have been screwin around with the runners and how to get them setup with a few failed attempts. I am planning to sell the 87 as I already bought a 64 so I just want to get it running good, try it out a few spins and then put it on the market.
Spending all of the LIMITED free time I have trying to Jury rig this SuperRam makes me think of returning to the OEM stuff!!!
Old Nov 30, 2005 | 06:08 PM
csheerin's Avatar
csheerin
What's the easiest way to slot the bolts? Dremmel? Band saw? File? Rock and chisel?
