95/96 LT1 cam
Old Oct 30, 2005 | 01:05 PM
Bruce's Avatar
Bruce
Default 95/96 LT1 cam
Can any body here tell me what is the lenght of the 95/96 dowel pin? I am going to do a Cloye double chain conversion later. I already a got a 95 timimg cover and 95 opti. But I want to keep my current custom cam. Therefore I am going to press out the shorter dowel pin on the cam and press in the longer dowel pin. I am going to use the C clamp and a deep sock go over the dowel pin and press it out. The last time I heard the dowel pin is about .720 long?
Old Oct 30, 2005 | 01:12 PM
tjwong's Avatar
tjwong
Bruce it is .620"
Old Oct 30, 2005 | 01:15 PM
Bruce's Avatar
Bruce
Tom
Do you happen to know the diameter? Because I have a whole bunch dowel pins at work that I measured some are .312 ans some are .250. I can just put them on the lathe and turn them to size.
Old Oct 30, 2005 | 07:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by tjwong
Bruce it is .620"
And it measures right at .250 diameter.
Old Oct 31, 2005 | 06:30 AM
Bruce's Avatar
Bruce
Awsome. I got crap load of dowel pin that measure .250 diameter and 1" long. I guess all I have to do is put it on the lathe and cut it to the correct length.
Old Oct 31, 2005 | 08:26 AM
tjwong's Avatar
tjwong
Bruce, once you pull the old pin out, and you may have to heat the cam journal in the dowel pin area to remove it. This will not hurt the cam although it may discolor it some from the heat no damage will become of it. I clamp the dowel pin in a vise, heat it, rock it back and forth using the vise as leverage point to remove the pin. Once the pin is out, a 1" pin should drive in deep enough without having to cut it down on a lathe.
Old Oct 31, 2005 | 02:40 PM
Bruce's Avatar
Bruce
Tom
Thanks for the tip. To be honest, I feel much safe by installing the Cloye Double chain because I feel the chain I got in there now will not survive the dyno pull later in the Spring.
To 95/96 LT1 cam
