need drag tires
Old Oct 31, 2005 | 09:24 PM
rugby!'s Avatar
rugby!
Default need drag tires
who has what? i just want 2 good drags for the strip and that is all i will use them for. do i want nitto555 or something else?
Old Oct 31, 2005 | 09:34 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
I've heard alot of good things about the micky thompson DR's.
SHINOBI-X's Avatar
SHINOBI-X
Rugby, I've used BFG Drag radials and M/T Drag radials on different cars i own.
On my vette i've used only M/T DR's and they truely do a very good job! I was very impressed with the performance of them. I think BFG's are just about as good as M/T's.
I've heard by many the Nitto's aren't as sticky as the BFG's and M/T's. I can't comment on the Nitto's so someone else will chime in with a accurate response.
Hoosier is making a drag radial now but i haven't seen it or heard of its performance yet. Maybe someone else will comment on the Hoosiers?
Old Oct 31, 2005 | 10:22 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I haven't tried the M/T's yet, but I hear they are just as good as the M/T ET Streets. The BFG drag radials are very sticky as well. Stay away from Nitto unless you drive more on the street than the track. The Nittos will last longer, but you need a longer burnout to get heat into them.
Old Nov 1, 2005 | 07:57 AM
LT4BUD's Avatar
LT4BUD
.........this brings up a question regarding street performance vs strip performance........usually on the street you don't stop and do a burnout to heat the tires........so what tire is best for the street for WOT traction at low speed/ red light start......
not racing of course.....just the ability to go full throttle at low speed without going into tire spin....
I really could use more traction on the street.......and an occasional trip to the strip
Old Nov 1, 2005 | 08:10 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Got some front runner for sale to make the front MUCH lighter and roll a lot easier....let me know.
And you can't go wrong if you just get a set of serious m/t slicks for the car. They will work better than most anything, and reduce even more weight.
Street/strip race wheels are nearly as heavy as the stock tires....
Old Nov 1, 2005 | 09:42 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
The BFG DR and the MT DR's are both awesome on the street. They have very low tire lifes though. I estimate a set of BFG's would only last 6k at the very most.
Old Nov 1, 2005 | 06:35 PM
Brimis's Avatar
Brimis
I've heard the BFG's are good.
Old Nov 1, 2005 | 07:49 PM
CFI-EFI's Avatar
CFI-EFI
I think Mr Mojo's and the comments of others on drag radial street worthiness refers more to wet traction manners and wear characteristics than traction on the street.
I have been running BFG Drag Radials, year round on my DD for about 5 years now. I avoid snow, but I drive it 9 to 10 months of the year. I admit to keeping the tires on the car until you can see the air through the tread, but I think they are staying on the car for 25,000 to 30,000 miles. May through October it "sees" anywhere from 3 to a dozen passes a week.
RACE ON!!!
Old Nov 1, 2005 | 09:26 PM
Mr Mojo's Avatar
Mr Mojo
BFG!!!
Old Nov 1, 2005 | 09:30 PM
the blur's Avatar
the blur
you should consider Kumho's.
Old Nov 2, 2005 | 01:13 PM
mike 1985's Avatar
mike 1985
the best ALL around tire i have used is a M&H Muscle Car drag tire. 305-40-16. This tire was good in the rain and hooked great at the track, and held it's own on the street.
I have seen pic's of cars launching on the hoosier drag radials too, they look real promising
Old Nov 2, 2005 | 02:08 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
You may want a drag specific tire/wheel pkg.
get a set of Centerlines and mount the BFG's (Or M/T).
That way you will keep your street maners/tires an switch to the drag package on weekends.
My two cents.
Matt383
To need drag tires
