Valve Question?
Old Oct 31, 2005 | 10:50 PM
Rtremain's Avatar
Rtremain
Default Valve Question?
Hey Everybody,
I am looking at some 2.02 intake and 1.60 exhaust valves in the parts forum. I want to keep the block stock but do some intake and head work. Will these valves be to much if I use them in my 91 heads for medium street applications and a little autocrossing? I realize the heads will need to be worked to take the valves. Input and advice as always is greatly appreciated.
Old Oct 31, 2005 | 11:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For sure you will need all new valve seats as 2.00/1.56 are the max for stock seats.
You should also deshroud (carefully) the intake valve. Start this work just beyond where the chamber begins to turn away from the adjacent water jacket.
Old Nov 1, 2005 | 08:04 AM
bluealtered's Avatar
bluealtered
Ok, i'm sure this will spark something, what rpm are you turning? 1.94's will work good up till 6000 rpm. You can gain some flow by working the angle of the seat. How long are you running above 6 grand? Deshrouding the chambers helps at any rpm,remember it's a air pump, you need the same flow all the way through for best results. joe
Old Nov 1, 2005 | 09:38 AM
Rtremain's Avatar
Rtremain
Good point bluealterd. I have the Lingenfelter book should have referenced. I have a 91 with catback, K&N so far. RPM wise I have put 3.54 gears in it and on the highway I am at about 2500 rpm at about 70 mph. on the street I am anywhere between 2000 and 4000 rpms. I know that it starts falling off at about 4300 to 4500. I have not had a chance to autocross since the gears but with the 2.59 it seem slow exiting. I would like to get at least 5500 and still be pulling.
Old Nov 1, 2005 | 11:54 AM
MYCoupe's Avatar
MYCoupe
Well if you're still using the stock TPI manifold and runners then that pretty much limits your airflow. Even with the bigger valves you'll never see 6K RPM with the stock TPI manifold.
Old Nov 1, 2005 | 12:44 PM
Nathan Plemons's Avatar
Nathan Plemons
I know on the LT1 at least the gain from going with 2.02 / 1.60 valves is minimal over 2.00 / 1.56 In most cases you gain very little high lift flow but you actually have a substantial loss in low lift flow. The result is a net loss under the flow curve, which means less horsepower. Certainly not what you would be looking for when you consider the costs involved in going with the larger valves since you have to have new seats, etc.
Your best bet would be to stick with 2.00 / 1.56 and place the money you saved on head work towards improving the intake.
Old Nov 1, 2005 | 01:05 PM
Rtremain's Avatar
Rtremain
Thanks Nathan. I am going upgrade intake. Looking at ported plenum, SLP runners, and manifold.
Old Nov 1, 2005 | 01:35 PM
65Z01's Avatar
65Z01
If you want to retain low end as well as extend the torque curve consider an Accel base & AS&M LT runners. You might not extend top end as much as with the SLP siamese runners but nor would you lose low end.
Also, for nearly no $$ you can try the siamese intake base mod. Going to a 2,000RPM TC more than compensated for the low end torque loss and the extended pull up top is very nice. Being able to stay in each lower gear for another 1,000rpm (my A4 now shifts at 5,800rpm) realy helps performance.
For some info on porting #113 heads and much more you might find this reference very interesting:
"How to Build Max Performance Chevy Small Blocks on a Budget", by David Vizard (ISBM 1-884089-34-8).
Old Nov 1, 2005 | 09:19 PM
Rtremain's Avatar
Rtremain
Thanks for the info 65Z01. I will look for the book suggested. Have you siamese your intake?
Old Nov 1, 2005 | 11:52 PM
65Z01's Avatar
65Z01
Yes I have done the siamese intake mod; the before & after dyno pulls and performance data are on my site. It is siamese stock size base with stock runners.
If you would like pics of the modded base, send me an e-mail at jgkov@msn.com refering to this post.
Old Nov 2, 2005 | 08:05 AM
bluealtered
The gear swap alone will help with your exiting speeds, if you need more try 4.10s, just a thought here, i know we all have steel cranks, however if you will have the engine out, check and make sure it wasn't a monday or friday engine and a cast crank wasn't stuck in by mistake, if you are going to play at 6000rpm, cast wont last. joe
Old Nov 2, 2005 | 08:33 AM
silver84's Avatar
silver84
is there any advantage to using
copper-alloy valve seats,
or sodium-core exhaust valves?
Old Nov 3, 2005 | 09:09 AM
bluealtered
The sodium exhast valves were first used on trucks for added cooling, for the money they cost you can almost go to titainum instead and be one hell of a lot lighter. As for the alloy seats i would have to guess that it simply makes a softer compond for unleaded use. (i'm sure someone will tell us)....for a racing applactions i've always ran hard seats simply because your always changing valves and seats anyway, plus hard seats will keep your flow rate the way you want it longer. joe
To Valve Question?
