Wheel width on a 95 coupe
Old Nov 2, 2005 | 11:03 PM
SUNNYD 95's Avatar
SUNNYD 95
Default Wheel width on a 95 coupe
Hi everyone, I would like to know how wide are the wheels on a 95 coupe, I just bought the car and want to change the wheels. Thanks, Jim
Old Nov 2, 2005 | 11:07 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Right now, you should have 9.5 rear and 8.5 front unless you have a suspension package.
Old Nov 3, 2005 | 08:30 AM
Gooseit's Avatar
Gooseit
I put 9.5 on the front and rear of my 95 coupe. that will make it possible to rotate your tires.
Old Nov 3, 2005 | 12:01 PM
MYCoupe's Avatar
MYCoupe
I would go with 17x9.5" all around. Even if you're not buying new tires for now. The stock front 255/45/17s will fit the 9.5" wide wheels just fine. When you decide to buy new tires just get 275/40/17 all around.
Old Nov 3, 2005 | 05:44 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Normally, you would want to go with the largest wheel/tire combo you can fit on the front of a car....but, the Corvette engineers decided on the narrower 8.5"/255 fronts on the last, most highly developed C4's for a reason.
If you don't need the last iota of front end grip (track car/autoxer), then you may be happier with the 8.5"/255's. I understand that it greatly diminishes tramlining.
Larry
code5coupe
Old Nov 3, 2005 | 08:28 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Larry what is tramlining?
BTW my 95 A4 came stock with 9.5 x 17 on all 4 corners because of the combination of FX3 and ZO7 options.
Old Nov 3, 2005 | 10:09 PM
chaos on wheels's Avatar
chaos on wheels
Tramlining is when the car follows the ruts in the road.
Old Nov 4, 2005 | 11:37 AM
MYCoupe's Avatar
MYCoupe
Originally Posted by rocco16
...I understand that it greatly diminishes tramlining.
Larry
code5coupe
While this is true, in my experience I didn't notice an increase in this "tramlining" when I stepped up to 17x9.5" wheels and 275/40/17 tires up front.
To Wheel width on a 95 coupe
