Drivers side window hitting???
Old Nov 3, 2005 | 11:54 AM
BIGJIM13's Avatar
BIGJIM13
Default Drivers side window hitting???
Hi
my drivers side window on my 93 Ruby has started hitting the frame up at the top right - what is the best fix for this problem?
Old Nov 3, 2005 | 12:02 PM
ED HEISER's Avatar
ED HEISER
Default drivers side window
If it is hitting the little metal piece the sticks out at the front, it can be adjusted with you fingers by pulling up on it. It can be bent down when you put on.
Old Nov 3, 2005 | 12:13 PM
BIGJIM13's Avatar
BIGJIM13
Yes it is hitting the metal piece as well as nicking the body -
does the window itself need adjusting?
Old Nov 3, 2005 | 01:51 PM
ED HEISER's Avatar
ED HEISER
Default Window Adjustment
Yes it can be adjusted every which way from inside the door panel, but you must be careful not to make any major changes. Why did it get out of adjustment. did you change the weatherstrip or remove the door or anything like that? If it has changed by itself over time, something has worn, like the door hinge. You may want to take it by a body shop and have a pro do it, or do an advanced search on this forum for ideas. This is a tricky job, but you can do it yourself if you take the time.
I have learned the hard way by breaking things to do your homework first, and go slow.
Old Nov 3, 2005 | 03:43 PM
clf93lt1's Avatar
clf93lt1
my 93 did the same thing the plastic stops on the window were bad
Old Nov 3, 2005 | 06:37 PM
tholm1's Avatar
tholm1
Mine was doing the same thing, the plastic stop that is connected to the window strikes a metal L-bracket bolted to the door frame...guess which one breaks first. The plastic stop on the glass also has a guide channel that controls the vertical track of the window.
Old Nov 3, 2005 | 06:40 PM
VenkmanP's Avatar
VenkmanP
Another vote for broken plastic stop. I reinforced the replacement with JB-Weld.
Old Nov 6, 2005 | 12:00 PM
BIGJIM13's Avatar
BIGJIM13
hi
thanks for the replies
what do you mean by the plastic stop?
I have taken apart the door and it sort of looks like the rear roller is where the movement is?
Old Nov 6, 2005 | 01:16 PM
clf93lt1's Avatar
clf93lt1
on the window there is a plastic guide bolted to the window that is what usely wears out if you have ahelms manual its on page 10-6-10
Old Nov 7, 2005 | 01:25 PM
VenkmanP's Avatar
VenkmanP
Here it is. Sometimes they are so broken off that people don't even know there's supposed to be something there.
To Drivers side window hitting???
