1987 Hi Blow Air Conditioning Relay
Cruising
'87 Hi Blow Air Conditioning Relay
Does anyone know where to install the Hi Blow Air Conditioning Relay??? My Haynes manual does not specify at all for my 1987 convertible and it is not locate near or on the air conditioner motor. Thanks in advance for all you help.
I believe that's '90 or even later years, Manual air only.
If you have Electronic Air, a (Blower) Module takes the place of any Relay. It's mounted on the left side of the Evaporator Housing. Inputs are usually red (Power from a fusible link behind the Battery), Dark Green/Yellow (Compressor on from the dash); Dark Green (Compressor Ground from the compressor); and Tan (Blower signal from the Dash - variable with about 2.5 volts at Blower Speed "1" and 6 volts are Blower Speed "10"). Outputs are Purple or Black Red (Actual Blower Voltage - about 4 volts at "1", 12 volts at "10") and Black (Ground - spliced or shared with the Blower Motor). If you don't have max blower - check voltages and jumper the blower motor directly to the battery to see if it runs any faster; otherwise, suspect the Module.
Received 1,404 Likes
If you have C68, you do not need this part.
