Found it!!
. I decided I would try it myself. Is it difficult to change? What do I need to know?
I'd appeciate any advice you can give. ---------------------------------------------------------------
I have a 1985 vette that I bought about a year and a half ago. It didn't run when I bought and I was told that it had some problems when he had last drove it (it sat for about a year before I bought it).
The first problem I found was a huge vacuum leak at the runner to intake manifold gasket (It had a lingenfelter superram plenum and runner with a 58mm throttle body). Basically I am just looking for stock performance so I removed the lingenfelter and replaced it with the stock plenum and runners.
It still didn't run very well so I asked some folks what I should try next. I was told that the 58mm throttle body was overkill for the stock plenum so I replaced it with a stock TB. It seemed to run better but still had a problem.
The problem is that at low RPM it will not idle smoothly and when I apply a little gas pedal it will bog and sometimes stall. I figured it was either a fuel problem or a spark problem. I set out to replace each component of both until I solved the problem. I replaced everything (plugs, wires, cap, rotor, coil, ignition module, fuel pump, fuel filter, fuel pressure regulator, EGR valve, TPS, etc.).
The problem is still there. One thing I noticed was that everytime I replaced something, the car would run good for a while. I then figured out that the problem could be corrected by disconnecting the negative battery cable. I then assumed that the problem was with the ECM. I replaced that but the problem still exists.
When I disconnect and then reconnect the battery, the problem seems to clear itself and the car runs great until I shut it off and restart it at a later time when it again will not run at low RPM. Any guess what it is?
85's have a Burnoff module behind the breadbox.
As far as reliability, I've been doing some surfing on the web and found out that this has been a troublesome part for a number of owners. Here is a quote from one website I looked at:
"NOTE: 1985 MAF systems used a MAF Burnoff module in conjuntion w/ the ECM and were very unreliable, and should be avoided."
I did check with NAPA and they quoted me around $350 for the part.
Yep! Just a burn off module that is very expensive, time consuming to replace and a bear to get to.
