Rocker stud Torque Spec.
Old Nov 5, 2005 | 01:52 PM
vetster86's Avatar
vetster86
Default Rocker stud Torque Spec.
I can't seem to find the torque spec's for rocker arm studs in my book.
86 alum heads, I think it should be around 50 or 55 ft. lbs. but not sure.
Can someone let me know the correct torque spec's. Thanks!
Old Nov 5, 2005 | 02:07 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That sounds about right. Put a little Loctite on them and you should be all set.
Old Nov 5, 2005 | 02:24 PM
vetster86's Avatar
vetster86
I looked through my book a few more times and found it, 50 ft lbs.
Old Nov 5, 2005 | 04:21 PM
CFI-EFI's Avatar
CFI-EFI
Unless the holes are through drilled into the intake ports, in which case a sealant would be a good idea.
RACE ON!!!
Old Nov 5, 2005 | 04:50 PM
vetster86's Avatar
vetster86
RACE ON!!!
Yes I always use a thread sealant when the holes are drilled through.
The rocker stud holes are not, the old studs I removed had nothing on the threads. I just used a little motor oil on the threads so they torque down good. Thanks for the help.
Old Nov 5, 2005 | 05:06 PM
CFI-EFI's Avatar
CFI-EFI
Most aren't, but the intakes are on my project engine.
RACE ON!!!
To Rocker stud Torque Spec.
