95 w/strange rough idle problem
Old Nov 10, 2005 | 08:50 PM
Lichen's Avatar
Lichen
Originally Posted by RAGOVET
My 95 VERT had a rough idle and when I had the IAC cleaned up some, it greatly improved it. Not completely gone, but not that noticeable. Rough running was only at idle. As soon as I hit the gas, everything is smooth.
How did you clean up the IAC?
Old Nov 10, 2005 | 09:17 PM
birdman2's Avatar
birdman2
Default Check the codes
Well I finally checked the error codes.
It was easier than I thought.
There were no error codes on the computer.
Any comments?
Birdman2
Old Nov 10, 2005 | 09:21 PM
birdman2's Avatar
birdman2
I checked for error codes. None were found.
Birdman2
Old Nov 10, 2005 | 09:23 PM
birdman2's Avatar
birdman2
Default Clean the IAC
I guess this is next.
What is the IAC and how do I clean it?
Birdman2
Old Nov 10, 2005 | 11:47 PM
Casethecorvetteman's Avatar
Casethecorvetteman
Birdman2
Thats idle air controller, and its located low of centre,on the right hand side of the throttle body, conected with a 4 wire plug.
