3" dual from the headers back
Old Nov 6, 2005 | 06:34 PM
LD85's Avatar
LD85
Default 3" dual from the headers back
Does anyone make an off the shelf pair of 3" exhaust pipes I could buy so I can eliminate the Y-pipe? My Hookers have 3" collectors and run to 3" pipes into a Y-pipe,
I would like to dump the y-pipe, and run 3" pipes back to my magnaflows
Old Nov 6, 2005 | 08:04 PM
88BlackZ-51's Avatar
88BlackZ-51
question, do u think the 3 inch pipe is too much? i was just thinking about it........what do u think? meaning 3 inch will loss back pressure, and low end tq wont it?
Old Nov 6, 2005 | 08:07 PM
LD85's Avatar
LD85
I dont think so on a 406, I think it will be fine.
I could have custom pipes made but I hoped that someone made a dual 3" like the dual 2.5" in the mags.
Old Nov 6, 2005 | 08:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Don't worry about not enough back pressure; all the tuning is done in the FL headers and collectors.
Ever notice how an engine dyno pull is setup? Mostly a set of FL headers with a realtively short section of collector-size pipe; and those people are after best overall results.
What is your engine build up?
How much expected peak HP at the crank?
Are you running cats?
What is the flow on those mufflers?
Old Nov 6, 2005 | 08:55 PM
85vet's Avatar
85vet
Cruise-In V Veteran
ld85,
check out my custom exhaust pics. I had a local welder fabricator weld it up.
http://photobucket.com/albums/a26/vet85us/
Old Nov 6, 2005 | 10:19 PM
FELNGR8's Avatar
FELNGR8
I have 3 inch all the way back. It's a custom job with X-pipe as well.
Old Nov 6, 2005 | 11:23 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Nothing off the shelf, I'm afraid. You'll have to go with a custom welded setup.
Old Nov 7, 2005 | 12:20 AM
Ramrod92's Avatar
Ramrod92
How much different is the L98s exhaust from the LTs. Here's my B&B 3inch w/xpipe.
Old Nov 7, 2005 | 12:23 AM
vader86's Avatar
vader86
B&B is 3-inch isnt it? I dont know if its 3" all the way for LT1s though, you could take theirs and adapt it. Either way, its not just a simple bolt-on installation.
Old Nov 7, 2005 | 04:50 AM
LD85's Avatar
LD85
As I figured, more custom work, oh well,, looks like a spring thing!
I will check into the LT1 set up some more, thanks guys.
Old Nov 8, 2005 | 08:06 AM
Slalom4me's Avatar
Slalom4me
Why not talk to Random Technology.
They have front adapters for Hookers. Their system is
3" from the collectors through an X-pipe to the cats.
While the default set-up is 2-1/2 pipe from the cats
back, perhaps they could work with you and offer 3"
pipe back from the cats?
One of the threads in this post has contact information.
Old Nov 8, 2005 | 08:27 AM
LD85's Avatar
LD85
Cool, I will see what they have and get some pricing.
Old Nov 8, 2005 | 08:33 AM
mike 1985's Avatar
mike 1985
that B&B exhaust looks nice. what's the price on that set up ?
Old Nov 8, 2005 | 09:52 AM
Ramrod92's Avatar
Ramrod92
TYBRNE Tom did have a group purchase going back in October.
Old Nov 8, 2005 | 03:24 PM
Raistlin's Avatar
Raistlin
Nice exhaust!
I went with a custom 3" setup using LTx hangers, Hedman headers, x-pipe, bullet cats and magneflow mufflers.
To use an LTx cat back on LD85's setup you may need to have some custom work done between the header collectors and where the cats used to be (beginning of the catback). I think even cutting up the y-pipe he'll be too short to mate to a catback system.
I'd say he's probably best going to a reputable exhaust shop and getting them to put some new pipes on.
I have all the GM partnumbers for the LTx hangers and D44. Let me know if you want me to dig them up.
To 3" dual from the headers back
