Service Engine Soon Light
Old Nov 7, 2005 | 12:55 AM
fosterj3's Avatar
fosterj3
Default Service Engine Soon Light
I have an '86. The Service Engine Soon Light continues to light up. I am in Australia and nobody has been able to tell me how to get it off. Engine has been recently serviced. Any help would be appreciated.
Old Nov 7, 2005 | 01:14 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
The SES light means there has been a problem and a code has been thrown.
You need to pull the codes and adress the issue.
Now if you believe the problem has been fixed you can clear the code by unhooking the negative post of you battery for 15 seconds or more and the code will clear and the light will go out. If the problem still exists a code will be thrown again and the light will be back.
Old Nov 7, 2005 | 02:02 AM
Aussie Vet's Avatar
Aussie Vet
Where abouts do you live, i am from wollongong, if you not too far we could meet up and i could scan the codes for you. If not, try jumping the aldl terminals and counting flashes to get the codes(see tech tips)
Old Nov 7, 2005 | 08:29 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Read this.......... http://members.shaw.ca/corvette86/No...it%20Check.pdf
If you find the code let me know and i will link you to the GM diagnostics for the code.
Old Nov 22, 2005 | 10:51 AM
Togo's Avatar
Togo
that site you referenced says to ground A to B - JUST TO BE SAFE - are those the top two on the left?????
Old Nov 22, 2005 | 11:08 AM
newbecorvetteguy's Avatar
newbecorvetteguy
As pictured, top right as you're looking at it.
Old Nov 22, 2005 | 11:20 AM
Togo's Avatar
Togo
so it goes
FEDCBA
GHIJKL
Old Nov 23, 2005 | 09:11 AM
rick lambert's Avatar
rick lambert
And DON'T start the engine-just turn the key to the on position for the code reading test.
To Service Engine Soon Light
