A buddy's fuel pump just died on his '96, and I offered to help him swap it out this week. I see my FSM (which is for a '94) lists draining the fuel tank as one of the steps. I can't, for the life of me, figure out why this should be necessary, and I've never heard of anyone doing it. Am I missing something here?
Also, any tips that go beyond the obvious, and beyond what's listed in the FSM?
I just replaced my pump took about 30 minutes from the top. Had a full tank of gas did not drain a drop. Easy process.
This is exactly what I've heard from everyone else who's ever changed out a pump on a C4, and it really puzzled me why draining was recommended. I wasn't about to drain the thing unless somebody on the Forum pointed out a really good reason why I should.
Thanks guys, for the reassurance. Gotta love this Forum.
My manual says nothing about draining the tank. I can think of a good reason not to drain it. It isn't the liquid gasoline that is so dangerous, it is the vapors, the air and fuel above the liquid that is so explosive. The more fuel in the tank, the less vapors to explode.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I know that the repair labor/cost book Chevy provides to the dealerships calls for dropping the tank and something like 2 hrs of labor. I forget exactly how much labor.
That lesson cost me about $200. The book is wrong. Mine was not done at a dealer it was from a private shop. The POS told me the book said 2 1/2 hours of labor to drop the tank and replace the pump. My car was dead at the shop so he had me by the hairs. When I went to pick it up I complained and he admitted he didn't drop the tank but the policy was to charge the book rate.
Wait, it gets better, the car still wouldn't start. Then he replaced the coil and it started and ran just fine. If it wasn't for the fact that the car has over 100k on it and it probably needed a filter and pump soon anyway, I'd really be pizzed.
Wow, what an azzhat. I can understand that they win/lose time with every job they do, and it supposedly evens out in the end, or rewards proficient shops, but in this case it's not that he's doing it quicker, it's that the book is plain wrong.
Had he dropped the tank and done it in 2 hrs, then I guess yeah, he should charge for 2 hrs labor UNLESS the customer calls him out on it.
Because you know if the shop took 3 hrs to do a 2.5 hr job, and charged you for 3, a customer "in the know" would be pissed.
These book times go out the window though on mutiple/overlapping repairs. Timing chain and water pump for example.. combined labor is way less than doing seperate. What would this shop charge you for on that?
I got hosed by a honda dealer on that once... I had paid to have the rotors cut, yet they charged me again for labour to replace the pads!!! Even tho the calipers come off either way.
RACE ON!!!
I couldn't agree more. Makes absolutely no sense to me, but the FSM (red) for my '94 lists as follows:
Fuel Sender Assembly Replacement
Remove or Disconnect:
1. Negative battery cable.
2. Relieve fuel system pressure.
3. Fuel filler cap.
4. Drain fuel tank.
...etc.
Beats me.
One thing's for sure -- I will be skipping Step 4.
I think the book may just be using the C.Y.A. policy. You know Cover Your A$$. They are covering theirs in case some shade tree hillbilly decides to have a Marlboro hanging out his mouth during the process of removing the fuel pump without draining the tank. Or uses his ligther to look in the tank.
Now as far as dropping the tank!! Well thats just retarded. Must just be one of those "help shops score easy charges" things.
I did mine from the top in about 40 minutes without draining or dropping and I wasn't in a hurry.
Re-read post number 8. Draining the tank makes for a bigger explosion. A full tank explodes with a lot less violence, but the fire lasts longer.
As CFI-EFI noted, the chance of explosion/fire might well increase, rather than decrease, with the tank drained than with it full, so I don't see this as a likely explanation.
I can only guess that some mechanics who didn't bother to look it up would just presume that the tank must be dropped, as this is the case on many vehicles. I dunno...
