Tranny leaking, need help
Old Nov 7, 2005 | 02:20 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Tranny leaking, need help
I was replacing my u-joints this weekend and noticed an oily residue under the car. Traced it all the way up to the tranny, looks like it is coming from the upper side of the tranny on the passenger side. I say that because there is a lot of fluid on the heatshield on that side. Could not raise my car high enough to get a good look(thick head), does this seem like a place for a leak?
It is an A4.
Old Nov 7, 2005 | 03:03 PM
Pete K's Avatar
Pete K
Check the fluid level. The overfill drain vent is located on the top of the trans. It has a twist so it points to the pass side of the unit. Also check the hard lines, servo cover, dipstick boot seal, tv cable seal and the edge of the tailshaft housing, where it meets the trans. I am guessing it is overfilled and coughed some out.
