Maybe special order. The non-smog version, 2151 is not coated. The 2151-1 is the same as the 2151 plus the ceramic coating. Hooker doesn't catalog an uncoated, C4, smog header, but they must wholesale them to other coating companies, such as Jet Hot, etc.
Not in the 2149s I don't think there is. That said, I wouldn't dare go with uncoated LTs in a C4. Things are soo tight in there. I have burned wires with coated tubes. And header wrap is just asking for a fire. Just my .02 cents, but if you can't afford coated, save up a little longer.
Who ever told you that un-coated headers was the way to go is wronggggggg. Get the ceramic coated headers from Summitt. I've had mine on my 91 Coupe over a year, and they work fine. You don't have to send they out to be coated, buying them coated from the factory. 2149, plus the the Y pipe. LOL.
Joe B.
He never indicated that uncoated was the way to go. He wants to install them first and THEN have them coated. By itself, that is not a bad idea, if one doesn't mind the extra work. Then, considering that Hooker only coats the outside of their headers, having them coated by someone else is a doubly good idea. I will refrain from my customary tube size comments.
Oh oh, ok, well in this case. Call up Jet Hot and see what they have to say.
They might sell the 2149s with their coating, infact I think they do.
Also try HPC, hi-performance coatings. They did my headers, for less then Jet Hot, and they look great. They might also be able to sell you some 2149s with inside and out coating.
Also, its totally cool if you run uncoated, its your choice. I just have seen what its like with coated headers in my 86 and that scares the crap out of me. (And started a flash fire when oil drip on the collector....so....imagine if they weren't coated)
2149 ceramic coated is what I recommend. I've had them on my car, and I've had my car upwards of 140 mph, never had a problem. But, it's your money, go for it.
" Hooker super competition headers (#2151). The headers
are 1 3/4"x3" collector size. The headers do not come with the EGR,O2
sensor and air pump set up). I can offer the header , fully coated
in&out with sterling silver, for $576+s&h "
