harmonic balancer mounting
Old Nov 13, 2005 | 09:07 AM
chrishoopes's Avatar
chrishoopes
Default harmonic balancer mounting
I seam to be unable to search the archives. Do both the arrows point up when mounting?
Old Nov 13, 2005 | 09:43 AM
prattman's Avatar
prattman
If you are talking about the timing marks on the timing gears, when they are at 12'oclock (cam gear) and 12'oclock (crank gear) then the engine is at #1 cylinder top dead center.
If you are asking how the balancer is installed on the crank hub, the bot have a raised area on them and you need to be sure they are aligned. I am assuming this is a stock setup. Yes the arrows point up.
prattman
Old Nov 13, 2005 | 09:47 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, the hub arrow and damper arrow should point up with the crank gear arrow also pointing up as when cylinders number 1 and 6 are at TDC with either one being in it's firing position.
To harmonic balancer mounting
