Rear Main Seal??
Old Nov 13, 2005 | 10:33 AM
DrEvil11417's Avatar
DrEvil11417
Default Rear Main Seal??
I'm finishing the rebuild of my new 'vette motor
The crank is a stock high mileage crank - all the journals are still within factory spec, however the old rear mean seal wore a groove into the back of the crank
My machinist wants to cut 1 rib off the new rear main seal. Does anyone know where I can get a rear main seal that rides on a different spot on the crank than the original one?
Old Nov 13, 2005 | 12:42 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That would make me dubious of your machinist. See if there's a replacement seal available that comes with a wear sleeve.
Old Nov 13, 2005 | 01:37 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Nov 13, 2005 | 01:48 PM
DrEvil11417
That's what im looking for. Anyone know of one?
Old Nov 13, 2005 | 06:44 PM
GOSFAST's Avatar
GOSFAST
Default 1 Pc. Offset Rear Main Seal
Corteco (Detroit Gasket) has the rear main seal for the late SB's. It has an offset designed into it. The part number is 17275. Thanks, Gary in N.Y.
P.S. If you can't get it locally, contact me. I'm on the island.
Old Nov 13, 2005 | 10:42 PM
DrEvil11417
yeah, if i could get the seal by the weekend that'd be awesome so i can put the motor in
To Rear Main Seal??
