95 Auto Trans Noise
Old Nov 13, 2005 | 10:57 AM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
Default 95 Auto Trans Noise
Hi All. Ive Got A 95 Coupe Auto. Had For 2 Years. Year Ago When I Slow To Stop Or For A Turn And Accelerate, The Trans Downshifts From Third To Second With A Clunk, Then When It Shifts From Second Up To Third There Is A Lighter Clunk.
Trans Man Thought It Was Simple Wear In Driveline, But It Doesnt Do It When Shifting From Reverse To Forward, Etc. Wheel Bearings Are Ok, Had All U Joints Replaced.
Any Suggestions?
Gordon
Old Nov 13, 2005 | 12:05 PM
Pete K's Avatar
Pete K
Corvettes use stiff accumulator springs. This combined with a solid mounted rear, tend to make these clunks. It is possible the trans was rebuilt and the anti clunk spring (used to hold the lo-roller clutch assembly tight)was left out. This is not likely because it would likely have torn out the case by now. Sounds like normal noise. I would look at the backlash in the rear next.
Old Nov 13, 2005 | 11:23 PM
UWEBABY's Avatar
UWEBABY
Pete, Wouldnt The Backlash Cause Clunking In All Gear Changes, And Especially From Reverse To Drive, Or Can It Be In Only One Gear?
Old Nov 14, 2005 | 02:45 PM
Pete K's Avatar
Pete K
True. I re read your origional post and it sure does sound like typical c4 driveline noise. I just freshened my trans and reduced the endplay in the box. Mine got a little quieter but is still there. It seems like endplay in the trans and case bushing wear compound this clunk a little bit though. I certainly would not worry or pull anything apart yet.
Pete K's Avatar
Pete K
Old Nov 15, 2005 | 06:21 PM
UWEBABY's Avatar
UWEBABY
Ok Pete, Ill Live With It.
Thanks For The Reply
To 95 Auto Trans Noise
