What is the highest usable, street valve lift on an LT1 hydraulic roller? Assuming the valvetrain is equal to the task (ie springs, pushrods, rockers etc.) could you use a cam that ends up at .605 intake and .624 exhaust lift with 1.6 rocker ration?
Hmmm. I've seen several LT1 head flow sheets up to .650, but that doesn't mean that it's possible to actually use that much lift. My own cam is .574 / .571 (with 1.6 RR) and I discussed going higher, but not to the lift you're talking. Why so much bigger on the exhaust than intake?
Idles at 800 rpms with a noticeable lope. A very streetable camshaft. Can lug the car around at 1200 rpms without a sign of cam surge.
I ran a 212/224 521/536 112+2 camshaft before this one, and the hp/tq curve was nearly identical until 5000 rpms, where this camshaft really takes off.
Oh well, it's not like mine will be a slouch up there. The duration is 230/236 and the lift is mentioned above. If I could get the damn car running I'd tell you all about it.
STL94 I think you are using the intake lobe I am looking at. Comp Cams lobe #3192. I am looking into a custom cam to match to ported heads. It's a little far off but I figure the extra research could be a good thing. I was thinking 224 intake at .605 lift, 236 exhaust at .624 lift on 114 LSA. I am hoping for pretty good street manners (mostly just vaccum and emissions passing) I am okay with lope and a little surge. I figure really good springs, and shaft rocker arms and the lift should be stable.
Your camshaft with 230/236 duration will idle rougher than my 224/230, even though you have less lift. It will probably even rev higher.
It's actually not bad. The car is not running right at this time, but surprisingly the idle is fairly smooth. I have more trouble engaging the clutch with the grippier disc and aluminum flywheel. The limit is set at about 6500 RPM. The top end should support over 7000, but the bottom end is stock. Once I go lightweight I plan to extend the usable range. We'll see where the peaks are with a dyno tune.
Anyone have a formula to calculate the volume of gasses brought in or expelled based on these two varaibles (lift and duration)? I'd be curious to see which plays a bigger part, the length of time the valves are open or how far they're open.
