Failed smog, help!!!!
Old Nov 14, 2005 | 08:32 PM
batoutofhell's Avatar
batoutofhell
Default Failed smog, help!!!!
I live in CA and have to go to a test only site. I changed the oil, spark plugs not to long ago, new oxygen sensor and pcv valve. I dont think the car is heavily modifed basically stock. Heres my numbers, any suggestions greatly appreciated. Car runs good with no codes.
15mph
HC / CO / NO
Max 128 / .80 / 1106
Measured 115 / 1.67 / 1119
25mph
Max 103 / .60 / 936
Measured 159 / 1.42 / 1018
I also throughly cleaned the IAC (dont know if that matters)
Old Nov 14, 2005 | 09:36 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
my no values were high also, but i have a leaky injector. oil change and air filter change, do not use an oil based air filter, just before taking it to the inspection station, might lower your numbers. check or change your plugs, check the wires and timing and fuel pressure. mine went from 1150 to 350 with a cat change and above, still high, but its the injector dumping in too much fuel
Old Nov 14, 2005 | 10:11 PM
batoutofhell
I just bought the car about a year ago so i dont know if the cats have been changed. what are the symtoms of bad cats and will this drastically reduce my numbers to pass? also, this is my first vet but its a 85 do they come stock with headers or is it suppose to be the block metal ones?
Old Nov 15, 2005 | 10:40 AM
batoutofhell
Old Nov 15, 2005 | 11:55 AM
SunCr's Avatar
SunCr
It's rich, so either the ECM thinks it's lean and is adding unnecessary fuel, or the CAT is shot. To find out, hook up a scanner and see what the Block Learn is at Idle and in whatever Cell is equilivant to the rpms at 25mph (or just drive it and capture data). With that info, we can narrow it down.
Old Nov 15, 2005 | 02:09 PM
CFI-EFI's Avatar
CFI-EFI
A rich mixture causes high CO readings. HCs are unburned fuel which can be another symptom of a rich mixture. Your NOx is close. It will likely come into line with the others. If not you can tweak the EGR or retard the timing a little to take care of the NOx.
RACE ON!!!
To Failed smog, help!!!!
