parking brake control
Old Nov 16, 2005 | 11:31 AM
jamie327's Avatar
jamie327
Default parking brake control
I'm having the typical problem of the ratchet that won't release when using my parking brake. I've read that the solution is to replace the control assembly. The only GM part number I can come up with is 12529393 which is listed as "LEVER". Does anyone know if this part includes everything necessary to make this repair? The list price is $95.51 which sounds considerably less than what others paid, which is making me question whether this is the correct part.
Old Nov 16, 2005 | 11:59 AM
brookman's Avatar
brookman
You just need to take it apart and clean it. the old grease turns hard. I cleaned and lubed mine and it works like it did when it was new.
