Resinator question
Old Nov 17, 2005 | 09:50 AM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Default Resinator question
I have a 96 LT4 with TPIS longtube headers running into 2 Random Tec high flow cats and then into the resinator . My question is I damaged the resinator when I blew out my rear tire some how . Do I need to replace the resinator or can I run straight pipes from the cats ? Any help would be appreciated . Thanks in advance folks ...oh by the way I have eliminators no muffs ..
Old Nov 17, 2005 | 10:22 AM
96 lt-4's Avatar
96 lt-4
you can run straight pipes no problem.it will probably make the exhaust louder.i replaced my resonator with an x-pipe.by the way,what kind of improvement did you see after installing the long tubes?before and after times would be great.mine will be going in sometime soon(i hope).have fun.
Old Nov 17, 2005 | 10:37 AM
DINO's Avatar
DINO
Thanks , as far as times . I have taken it to the track before and after the install but its been about 3 or 4 years since the install all I know the times were much better by at least 1 to 2 tenths of a second but I am not the greatest when it comes to the 1/4 mile ...
Old Nov 17, 2005 | 10:39 AM
FD2BLK's Avatar
FD2BLK
I have a 3" BB resinator collecting dust if you are interested let me know
Old Nov 17, 2005 | 10:54 AM
DINO's Avatar
DINO
Thanks for the offer Paul , I will keep it in mind ..but I'm hoping that I could go without it as long as the car is not crazy loud .... ...some great people on this forum .
Old Nov 17, 2005 | 12:21 PM
FD2BLK's Avatar
FD2BLK
If you are looking to eliminate the resinator then I would go with an X pipe.
Old Nov 17, 2005 | 04:09 PM
DINO's Avatar
DINO
Anyone else ...
Old Nov 17, 2005 | 05:08 PM
93 ragtop's Avatar
93 ragtop
Dino, alot of guys have removed the resonator and installed a x-pipe. I personally plan to try this. http://cgi.ebay.com/ebaymotors/3-Mag...spagenameZWD1V
It is 3in in and out and is supposed to have a tru-x design, which is an internal x pipe.
Old Nov 17, 2005 | 09:17 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Yo DINO!
Old Nov 18, 2005 | 09:31 AM
DINO's Avatar
DINO
Yo Franky , give me a call someday !! I want to put on my rotors !! Help ! ...732-598-9417
Old Nov 18, 2005 | 12:04 PM
Strick's Avatar
Strick
I plan on doing the same thing. Dr.Gas has them, but they are expensive! I, too, will have a B&B resonator hanging around collecting dust.
Old Nov 18, 2005 | 12:55 PM
DocSpeed's Avatar
DocSpeed
Are you guys using Corvette specific X-pipes or are the universal?
I too thought about removing the resinator but didn't know if I would benefit from it or not. If it will give me a .1 or two at the track and make the exhaust a little louder, I defiently need to put the X-pipe on my to do list.
Old Nov 18, 2005 | 02:42 PM
DINO's Avatar
DINO
Thanks for all the replies guys . I am going with the x-pipe ...
again thanks for all the input to make my decision easier ...
Old Nov 18, 2005 | 02:43 PM
Strick's Avatar
Strick
Dr.Gas will make an X-pipe to fit your exhaust. Just give him the dimensions and he'll make it to fit. Yes, replacing the resonator with an X-pipe will make it louder and according to B&B, it should be 30% louder, inside and out. As far as better times at the 1/4, the jury is still out. B&B says they only make a less than 10 horsepower change and that was on an LT4.
Old Nov 18, 2005 | 05:25 PM
DocSpeed's Avatar
DocSpeed
Thanks for the info man.
Old Nov 18, 2005 | 07:41 PM
bobmic93's Avatar
bobmic93
I have a 93 with Corsa and I cut out the resonator and ran straight pipes . It has a much more agressive sound now, you can really hear the exhaust fow through the pipes as you let off the gas pedal. I love that, but on long rides at high speeds the resonace is there.
To Resinator question
