Installing camber-brace PITA
Also, while we used the "new" bolt on the passenger side, (maybe because we didn't know to jack up the car as Shawn did), what we did is reuse the "stock" on the driver's side. Works just fine! And Dave DID walk us through it a bit (at about 845pm on a weekday, no less! what a guy!)
Finally, one thing we did as we were installing the first one which may be a big no-no, is to carefully, very carefully bend those two a/c aluminum lines outward (maybe a quarter of an inch), away from the compressor (?) so that there was good clearance. And on either side, we used one shim or two and Sam even filed one down for each install so that the CBrace slipped in without a problem.
Nope, it wasn't a cakewalk. But it works. Hope yours does, too.
