I'm not super mechanically inclined, but I'm not a total idiot either. Been trying to install my new camber brace for last two hours. I'm having a rum and coke now to settle down. Followed the instruction to the tee, but the sucker just won't squeeze in there. Plus the instruction don't mention that in order to remove the driver's side bolt, you need to remove the serpentine belt. It's just sort of wedged in there now. I will try again Saturday morning. If I can't get it installed, I will remove it and sell it ( if I don't have to get a torch and cut it in half to remove it. I could have made one at work about 1/4" thinner that would fit for about $10. Sorry Dave, but I am kind of pissed-off right now. Go ahead and flame, guys.
Had to take the belt off to get my d/s bolt out.Once that bolt is out then it goes togther a lot easier.So if you haven't taken the bolt out do it now.
I imagine if you had someone on the other side pull up on the tensioner while you get the bolt out it might work.I could not try that as it took 2 hands to get the bolt and I did it by my lonesome.
That's what I was thinking. If there were two of us, it would have been a lot easier. It's dark out now, so I'll get some help Saturday morning and remove the belt. It's probably just the fact that it was after work with only a little bit of sunlight left that made me go ballistic. Where's the Valium!
If you haven't removed the driver's side inner fender panel (remove three 10mm bolts at the rear of the panel and loosen the two 10mm bolts that secure the front), you're making life waaaaaaaay too difficult. Remove the inner panel on the passenger side the same way (it also has two 7mm bolts that hold the metal coolant lines to it).
You don't need to remove the serpentine belt to take the bolt out. The belt will slip off the idler pulley (push it towards the front of the car) that bolts to the accessory bracket and you can easily slide the belt back over the pulley when you reinstall the bolt. You'll still need to dodge the ps pump pulley. If you look at the bolt head you'll notice it's squared off on two sides. Rotate it so one of the squared off sides slips past the pulley.
Some of the Camber Braces I've seen are slotted where the bolts pass thru versus having a hole. If you have a slotted one, there's no reason to remove the bolt, you only have to loosen the nut enough to slip the CB in behind the bolt head. Dave supplies longer bolts for those cars that are set up with tons of alignment shims, but you can use the stock bolts without issue. In fact, the stock bolts are formed (behind the bollt head) so they won't spin when tightening the nut.
Thanks for the tips. I don't mind removing the fender panel.
I've put mine on twice, only removed the belt the first time because I needed to replace it anyway. You'll be glad you went through the "trouble" once its installed and take the Vette for a "spirited" drive.
You might of gotten one to fit easier, but I know Dave, he made it that way for a reason. I would think that he made it that heavy duty to with stand the stress under hard turns. If it flexs or bends it would give you no benifit. Sure, the materials may not add up to a whole lot, but you have to factor in the research time. Many products sell for many times more then the sum of their parts, but R&D drives the price up. Many companies invest a lot of time and money to make a product that will perform the way its suppose to. Heck, you would be mad if it were cheaply made.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I ground a chamfer into that bolt hole so I could get more room to get the bolt in from an angle. Seems like it'd be easier to install if the slotted holes were rotated 90*
Does he make an aluminum one? This thing is damn heavy.
Ive never seen one of these in anything other than pictures, but you would have the front jacked up to remove load from them wouldnt you? Just looking down the from of my right hand drive LT1 engine bay i really dont know if id even be able to fit one, my heater lines run through there to the left side of the car, along with A/C lines that are not normally there...
Here is a pic, what do you guys think? I know its hard to say from the angle, but do you think id fit one?Thanks in advance for your help
If you put a jack under the front crossmember and jack the car up, the upper A-arm mount will flex as much as a quarter of an inch giving you room to remove that bolt. That's exactaly what the camber brace is there to do, reduce that flex!
them wouldnt you?
Not on my '89 but this might vary car to car due to mfrg tolerances
or accumulated adventures.
Originally Posted by Casethecorvetteman
Just looking down from the top of my right hand drive LT1 engine bay i really dont know if I'd even be
Looking at your pics, the heater hoses won't interfere once the bar is
in place (it sits lower) but they may slow down installation.
Edit: (The A/C reciever-drier below and to the right of the intake
snorkle might be a problem.)
Actually it looks like it is in the same location as FelnGr8's
It's a bit of a sideways view from both sides, maybe you can see how the Camber Brace fits through the normal plumbing.
Arrrr yes, i see where it goes, i didnt know it actually went behing the compressor lines,that would solve a few issues on that end, as for the centre ill have to have a good look when it gets to be day time. Thanks mate.
Yeah as far as i know, that is the stock location, i dont think it was moved during conversion to RHD.
