How to replace high beam indicator on dash
Old Nov 19, 2005 | 02:42 PM
dmorris's Avatar
dmorris
Default How to replace high beam indicator on dash
I've tried the search and haven't found anything. I need to replace the tiny bulb for the highbeam indicator on my 85. I'm looking right at it but it doesn't want to come out. It appears to need to twist and pull out, but it isn't budging. Is it a push in or twist. I don't want to break something and make matters worse.
How many corvette mechanics does it take to change a light bulb?
Old Nov 19, 2005 | 05:05 PM
Bob CTS's Avatar
Bob CTS
Going off memory I think it should come staright out, if the base turns it will fall into the dash cluster box thus requiring you to remove the cluster and open it up because it pushes in and turns from the inside of the cluster, kind of like the lights that light the cluster.
Bob
Old Nov 19, 2005 | 08:30 PM
dmorris's Avatar
dmorris
Thanks. The more I looked at it, the more it looked like it would fall into the cluster.
To How to replace high beam indicator on dash
