Rocker Sucess!!
Old Nov 21, 2005 | 12:35 AM
Irishpilot03's Avatar
Irishpilot03
Default Rocker Sucess!!
Finally, after figuring out that I had tried to install the 1.6 RRs 30 degrees off of timing, I got it right and found the number 1 piston's dead center. Originally, I set the RRs off of the crank pully 12 o'clock position; unfortunately, I have a smaller pulley, so the mark was useless. I used the GM tech book's method of setting RRs off of the number 1 and 6 piston positions. It worked great and the car sounds and runs great. Now I need to figure what type of heads to start shopping for. I'm looking at ported LT1 heads. Has anyone had good experiences with AI ported heads? Thanks for the help!
Last edited by Irishpilot03; Nov 21, 2005 at 12:44 AM. Reason: Forgot to add signature
Old Nov 21, 2005 | 01:23 AM
bacardioil's Avatar
bacardioil
try portpros.com. in TX, ask for harold. tell harold gene told you to call. what a set of lt4 heads he did for me. right now he building me a 383 engine. the man worked for some of the top engine builders in the country before opening his own shop. i can tell you this the guy knows his sh--.
Old Nov 21, 2005 | 11:58 AM
MYCoupe's Avatar
MYCoupe
Both AI and LE do very good work. Can't go wrong with either one.
To Rocker Sucess!!
