ttspowersystem help scanner trouble
Old Nov 21, 2005 | 07:07 AM
rugby!'s Avatar
rugby!
Default ttspowersystem help scanner trouble
i downloaded the file to scan my 91 vette thur tts but i can't get it to start the datamaster32 engine recording screen comes up but it won't start recording or even letting my see what my car is doing without recording. i want to use the 20 free recording but i can't figure it out. i think i need an authorization code has anyone done this before thanks for the help
jeff
Old Nov 21, 2005 | 08:33 AM
JackDidley's Avatar
JackDidley
You get 20 free runs. Not sure what screen you are seeing, but you can close the little registration one. On the toolbar click file, open file, name the file, test the com port, if it says OK, click start.
Good luck.
Old Nov 21, 2005 | 10:13 PM
rugby!'s Avatar
rugby!
spankyellow thanks for the info. i went thur everything and when i tested the com port itcame up with a box that said
aldl adapter is working but no pcm was detected. check the cable connection between the adapter box and the pcm. this can also occur if the datamaster version is incorrect for the vehicle.
i checked it and i have the 8d version so that is ok. so why is it telling me no pcm detected?
Old Nov 21, 2005 | 10:38 PM
JackDidley's Avatar
JackDidley
Do you know if the car has the original chip ? Some aftermarket chips are modified so you cant scan them. I had problems getting mine to hook up at first also. Its been 2 years so I cant remember all the stuff I tried before I got it. Dont give up. Once you succeed its a great tool.
Old Nov 22, 2005 | 02:00 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
jeff
You need datamaster version 8D. Try that..
Old Nov 22, 2005 | 08:38 PM
rugby!'s Avatar
rugby!
i have the 8d version. so i know that part is right. i still need some help getting for program to work someone please help
Old Nov 24, 2005 | 06:27 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Did you turn off all infered devices in your computer?
Did you turn off the modem?
Did you down load the ADL tester from the site.
Old Nov 27, 2005 | 11:17 PM
YoMilkMan's Avatar
YoMilkMan
What year vette? What ECM? It will still data log even with a after market chip
Old Nov 28, 2005 | 09:11 PM
rugby!'s Avatar
rugby!
i turned the laptop on and hooked it up to the car. and i have downloaded the aldl tester and tried the test and it still comes up with the same box that says no pcm detected. my vette is a 91 and i assume the stock ecm. i have a chip from fastchip and it is giving me 360hp and 425tq from my 383 but they don't seem to want to help me get everything out of the chip that i can. so i got a chip from alvin from pcmforless and i put it in and it ran bad so i turned my fuel pressure down to 40# and it ran better but it hardly spinns the tires and with the fastchip i can spin them at 40 no problem. with the pcmforless chip it hardly chirps the tires at takeoff. alvin would like some datalogging so that is where i am at now. someone help me out thanks jeff
Old Nov 29, 2005 | 12:42 AM
REDC4CORVETTE
You will need a 10 khom resistor to make the adl to work.Radio Shack has them.
Old Dec 4, 2005 | 11:57 AM
SBNova's Avatar
SBNova
I tried Datamaster from TTS, but I never could get it to work (link to the ECM). I have successfully used WinALDL and TunerPro RT- although TunerPro took some work. I used the same cable on all, two different laptops- one with a serial port and one with an adapter. Still no Datamaster. Oh well.
Old Dec 6, 2005 | 09:53 PM
rugby!'s Avatar
rugby!
sbnova, winalad worked for you? did you get some good info. i had a chip done by alvin at pcmforless and the chip isn't very good so i wanted to get some logging done so he can reburn the chip. so if winaldl will give some good info maybe i should try that?????
To ttspowersystem help scanner trouble
