315's and speedometer
Old Nov 21, 2005 | 07:43 AM
jwt1603's Avatar
jwt1603
Default 315's and speedometer
If I put 17 X 11 wheels and 315 35's on the rear of my (non ZR1) 94 will it make the speedometer incorrect as the tire diameter is different? Or is this a non issue?
I tried to search and didn't come up with anything.
Old Nov 21, 2005 | 07:58 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The tire diameter isn't different by much if at all. Truthfully I never did measure to see the difference if any.
My speedo seems to be right on since I pass those RADAR machines on the side of the road and my speedo matches what the RADAR says.
Old Nov 21, 2005 | 08:40 AM
jwt1603's Avatar
jwt1603
Thanks a lot.
Old Nov 21, 2005 | 09:13 AM
ittlfly's Avatar
ittlfly
The short answer is, No. As long as the height are approx the same.
Old Nov 21, 2005 | 11:53 AM
MYCoupe's Avatar
MYCoupe
As the other have stated you will be fine.
285/40/17 tire - 25.98" diameter
315/35/17 tire - 25.68" diameter
You can see that it's only a difference of 0.3", which is negligeable because your speedometer will only read 0.7 MPH too fast.
To 315's and speedometer
