'93 stalling
Old Nov 23, 2005 | 03:48 PM
rbeckert's Avatar
rbeckert
4th Gear
Default '93 stalling
Last Sunday evening I took my '93 40th Anniv out for a ride. It ran great for about a half an hour. It got dark, I turned on the headlights, was running about 60-65mph and the car stalled. It started right back up, but continued to stall about every three miles all the way home. I took it for a short ride the following morning and it ran fine, never stalled. Could the stalling have anything to do with headlights ?
Old Nov 23, 2005 | 04:01 PM
swifty's Avatar
swifty
Headlights don't compute - but it's real easy to check. Turn on the headlights during your daytime drive and see what happens.
I'd look for a heat-related failure before headlight-related. Several electrical components can change state with heat soak.
First check (always) - did it throw any codes? Check and post results if you still need an assist. Good luck,
Old Nov 25, 2005 | 09:09 AM
dlmeyers's Avatar
dlmeyers
Just out of curiosity, what is the alternator output at idle? Then measured with a load, as in headlights, fan on, etc.
dlmeyers 90 coupe zf6 3 speed shocks
Old Nov 25, 2005 | 10:56 AM
Jet-Jock's Avatar
Jet-Jock
Are you familiar with pulling DTC codes? Surely there would be a DTC set for this type of condition.
Old Nov 25, 2005 | 11:00 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well, this happened to me on one of my older cars. At night, with the headlights on, stereo going and the wipers on, if I flicked on the high beams, the car would stall.
I never chased down the exact problem since it had a new alternator,new battery,new starter and new battery cables. All the other wiring was original(1968). Definitely an electrical problem in my case.
To '93 stalling
