water pump install questions
Old Nov 25, 2005 | 04:05 AM
imabolr's Avatar
imabolr
Default water pump install questions
I'm getting ready to re-install the water pump on my 1996 LT1.
The Haynes manual and other literature I've read says to put RTV sealant on both sides of the seals before reinstallation.
My question is - what about the bolts so they don't leak? When I took two or three bolts out they were installed by the factory with some kind of thread lock or sealant. What do I put on those bolts? and also the temperature sending unit?
Old Nov 25, 2005 | 07:47 AM
Strick's Avatar
Strick
Yes, you need to put a thread sealer on the water pump mounting bolts. I have great results with Permatex's Aviation Gasket Maker, which I also use on the water pump gaskets, both sides. No leaks for the past 4 years. Also, here is a link to an article I wrote on installing a Meziere Pump. In it you can find how I mounted the water pump.
https://www.corvetteforum.com/techti...=231&TopicID=2
Old Nov 25, 2005 | 10:24 AM
96_LT4_FE1's Avatar
96_LT4_FE1
I'd like to add that make sure its a quality pump(next time, its dealer for me), I bought an el-cheapo $160 "signature series" pump from advanced(no one else even stocked a pump), and it leaked out of the box, I ended up using bars leak on a new rebuild cause I had a track event the next day.
Also, the metal used and the radius bends of the nipples were nowhere near factory quality.
JMHO, »keith
Old Nov 25, 2005 | 11:38 AM
ScaryFast's Avatar
ScaryFast
I didn't add anything to the bolts. They shouldn't leak. I've had my pump off 6 times with no issues or leaks.
Put teflon tape on the temp sensor if you replace it.
Old Nov 25, 2005 | 05:31 PM
Strick's Avatar
Strick
Doesn't that interfere with the ground on the sensor?
Old Nov 25, 2005 | 10:45 PM
ScaryFast's Avatar
ScaryFast
Hmmm...maybe I should check. Seems like I did but I could be giving bad advice.
Nope, no tape. I'm thinking of the plugs in the heads which I just replaced a few weeks ago.
Sorry about that.
Old Nov 26, 2005 | 11:12 AM
EvanD's Avatar
EvanD
CF Community Team
Do they sell bearings and seals to rebuilt the pump yourself? I have a leak somewhere at the pump and need to pull it soon, looks very easy.
Old Nov 26, 2005 | 12:12 PM
ScaryFast's Avatar
ScaryFast
As far as I know, they don't sell anything other than the seals. That should be all you need. The inside is simply an impeller, a bearing, and a shaft that sticks through the back and is driven off of the crank.
If you have a leak it's probably one of the seals between the block and the pump.
I have a used pump (that worked fine) if you need one and don't want to buy a new one.
Old Nov 26, 2005 | 09:10 PM
Strick's Avatar
Strick
This amazes me. As much work as is required with pulling a water pump, why not install a new AC Delco (OEM) pump and forget about it for another 50K? Better yet, install an electric coolant pump. The problem with the OEM pumps is the bearing gets sloppy and the shaft looses it's seal and starts to leak out the weep hole. That same shaft can also loose it's seal as it goes through the timing cover and there is another chance of an oil leak.
To water pump install questions
